Old 11-04-2009, 12:11 PM   #61 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
Quote: Originally Posted by Xx_R/T_xX View Post
mine is still acting up..jeeez this is gay..its actually causing me to knock now...i foot is no where near the clutch and all wiring is sodered correctly..guess its gonna have to come out then
ive had mine on the past 2 days full time and i noticed it cut out on me once at part throttle boost for no reason just a quick stutter.
could there be extra noise in the wiring somewhere from a mod? sharing grounds?
also would having a very stiff ride and hitting a bump under load be enough to shake the clutch pedal enough to get it to cut? that would explain that one time earlier ^^^
bene is offline   Reply With Quote
Old 11-04-2009, 12:16 PM   #62 (permalink)
bene's Avatar
Trader Rating: (40)
Quote: Originally Posted by ticaaal70 View Post
Well it bogs everytime at 3400 rpms or when im about to hit boost. It bogged alot when I had the settings to auto.
I still love this thing i dont want to disable the wot box but my car is running like crap because of it.
I played with the settings today and I changed the settings of the no lift shift to 150 and it seemed to help out quite alot. It doesnt bog as much.
is it bogging or cutting out on you?
Old 11-04-2009, 09:57 PM   #63 (permalink)
dsmbenchpress's Avatar
Member Number: 75833
That's probably different. I think that is probably the lockout. Try turning off the lockout and see if it works all the time for you.
what do you mean lockout?
dsmbenchpress is offline   Reply With Quote
Old 11-04-2009, 10:15 PM   #64 (permalink)
bossierboy's Avatar
Member Number: 75522
u should check ur spark plugs bro i had this problem. i now use pulstar plugs and car runs great!!!
bossierboy is offline   Reply With Quote
Old 11-04-2009, 10:20 PM   #65 (permalink)
Member Number: 33203
Trader Rating: (25)
Mines been doing fine as long as I keep the box turned off, I did start getting a couple counts of knock at the same time as this started happening. Not sure if it's a coincidence or not. Today I finally decided to check out the clutch wiring and turns out I found one wire that was lightly skinned, and then one wire that was cut in two. I'm not 100% sure what wires they were, but considering the wot box is the only thing giving me trouble, I'd say that's where they went. I'll find out tomorrow if it works again or not. If so, I'm going to the track sunday for the first time in forever.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 11-04-2009, 10:52 PM   #66 (permalink)
bene's Avatar
Trader Rating: (40)
"The lockout is slightly different.....
It checks the RPM when the clutch is pushed down, not when the gas is pushed down.
So, it goes like this:
-in gear
- clutch in : is the RPM below the lockout (1500 default)?
- if yes, 2step is allowed
- if no, 2-step is not allowed
- now, until the clutch is lifted and pushed down again, the 2-step remains enabled or disabled depending on the last result
- next, if you floor the gas, the 2-step will be enabled at WOT.
So, typically you have to go to neutral and release the clutch before you can unlock the lockout. If you just roll to a stop with the clutch down, put it in first and then mash the gas, it won't be enabled.
The reasoning is that you can stage and leave the 2-step enabled.
but, it can be hard to get it engaged. So, my new advice is to just turn it off and only enable it if you are having a problem with it engaging while moving."
Old 11-05-2009, 01:35 AM   #67 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
ya same goes here jon..i started to see about 2-4kr of knock when the cut out occurs...turn the box off and no more knock..
BIG TURBO!
Old 11-05-2009, 03:00 AM   #68 (permalink)
ticaaal70's Avatar
Member Number: 64715
Trader Rating: (24)
Hopefully i could get mine to get fixed.
ticaaal70 is offline   Reply With Quote
Old 11-05-2009, 05:18 AM   #69 (permalink)
Trader Rating: (25)
See mine doesn't really show it when it cuts out, but of course I've only went wot long enough for it to cut out once since finding out that its the box. I forgot to turn it off one day. I'm seeing a little knock without it cutting out. Like I said, it may just be a coincidence. I've always seemed to get more knock when it's cold outside than when its hot, so now that winter is coming, maybe that's the cause. I'll just hafta play with the boost and see, or try turning the meth pump up.
Old 11-05-2009, 08:06 AM   #70 (permalink)
Member Number: 25854
Trader Rating: (95)
Send me the screenshots....
Old 11-05-2009, 11:59 AM   #71 (permalink)
bene's Avatar
Trader Rating: (40)
keep posting back guys, were gonna get this fixed. sending him screen shots will help alot
Old 11-05-2009, 01:05 PM   #72 (permalink)
Trader Rating: (25)
I'd be willing to bet that 99% of the issues in this thread are to blame on the installer/car more so than the wot box itself. I rode with my dad to work this morning so I haven't driven mine yet to see if fixing the cut wire took care of the issue or not, but it should have. I'm sure I'll drive it later this evening. Forza3 has my attention right now haha.
Old 11-05-2009, 04:02 PM   #73 (permalink)
Xx_R/T_xX's Avatar
ya wiring might be an issue,but the way my luck is,its not always the labor that doesnt work out in my case
Old 11-05-2009, 04:04 PM   #74 (permalink)
Sota's Avatar
Member Number: 31159
I had my car out today. it seemed to be running better and I noticed my AFR's are up to about 10.4:1 now instead of near dead 10.0:1 also breaking up was less with the box turned on. I think my issue is too much fuel.
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 11-05-2009, 04:15 PM   #75 (permalink)
ticaaal70's Avatar
Trader Rating: (24)
I dont think my installer did it wrong...
Page generated in 0.16172 seconds with 13 queries
