Old 06-19-2008, 07:34 PM   #1 (permalink)
Member Number: 54802
Default boost sensor
had a dtec in the car and it took a crap, even while it was crappy i had no cel's went and got a safc2 put in and now boost sensor code showing up I'm guessing on an obd2 scanner cause its in the shop and not sure if they know how to check the code. the guy tells me everything is working fine but the damn cel is on he said the computer might be f'd up but I cant believe that any ideas guys?
AGP wga, 3" tbe no cat, atp upp, hks ssqv, agp returnline, k&n intake, agp dog bone mm, short shifter, greddy tt, safc2, AIS intercooler, 255 fuel pump, b/s chain removed, aem wideband, MSD tach driver, fuel pump rewire.
279 hp
317 tq
fastloudfzr is offline   Reply With Quote
Old 06-19-2008, 07:36 PM   #2 (permalink)
goats srt's Avatar
Member Number: 47689
whats the code number
goats srt is online now   Reply With Quote
Old 06-23-2008, 01:39 PM   #3 (permalink)
the guy at the shop used the obd2 scan tool and found the boost sensor problem and he said it idles fine but when you go into boost its shit he said he checked before and after the map sensor and there is voltage then he applied boost and the voltage did change he even has voltage all the way to the plug going into the ecu which is why he thinks the ecu is not reading it. I just went over there today and checked codes with the key and got p0325 and p0340? any ideas would be great he thinks the ecu is shot and I have access to another but would have to get it flashed and thats another 120 bucks i dont have
Page generated in 0.12503 seconds with 11 queries
