Old 05-10-2006, 06:44 PM   #256 (permalink)
riceisnice's Avatar
Member Number: 20625
Quote: Originally Posted by EDISKRAD EHT
Anyone ever have boost leak from the breather on the driver side of the valve cover? It's even still there when i take the other PCV line (i have a catch can and check valve) completely off and plug it.
X2 Exact samething is happening to me
riceisnice is offline   Reply With Quote
Old 05-10-2006, 07:32 PM   #257 (permalink)
phubarr's Avatar
Member Number: 36947
Trader Rating: (39)
riceisnice are you using the stock airbox or do you have an aftermarket intake?
2005 Black Dodge SRT-4 ACR - SCT PRP, NDE TCS, Mopar Stage 3 Coilovers, Falken RT-615's, AFE Stage 2 CAI, Ported 52mm TB, Kinetic WGA @ 17psi, MaxxFab 3" DP (catless), Innovate LC-1 wideband, Aeroforce Scan Gauge, and a Hurst Shifter.
1989 Black Dodge Daytona Shelby Turbo II
1972 Plum Crazy/Black Plymouth Roadrunner
phubarr is offline   Reply With Quote
Old 05-10-2006, 08:32 PM   #258 (permalink)
riceisnice's Avatar
Stock airbox
Old 05-11-2006, 08:00 PM   #259 (permalink)
punishersrt4's Avatar
Member Number: 38568
well i have a serious leak or something. i just installed jmb pipes and all the t bolt clamps are tight. but my car is only boosting to about 10psi and drops from there. i dont even get a discharge from my bov. any suggestions. im going tonight to get stuff to do a leak test with. what kind of tank do i use to check it with.
2004 Black SRT-4
MODS
[X] IM MODDED
http://www.fullybuilt.com/ IN THE 808 STATE
(702) 943-8803 (Shop Line 9-5 Mon-Fri Part Of Sat) Paypal - FBMHelp@hotmail.com
punishersrt4 is offline   Reply With Quote
Old 05-16-2006, 05:45 PM   #260 (permalink)
all_bran's Avatar
Member Number: 22506
Ok, sorry but I'm not digging through 18 pages of this thread. How do you get to the one at the turbo outlet? Is it as easy as removing the air intake tube? I have an AEM CAI and I'm trying to avoid taking it off, it's a PITA to get back on.
Black 2004 SRT4 now gone
Black 2007 SRT8 Charger in garage
all_bran is offline   Reply With Quote
Old 05-16-2006, 05:52 PM   #261 (permalink)
Senior Moderator
stowaway's Avatar
Member Number: 3286
yeah, remove the air intake and reach under the turbo to get at the clamp.
Old 05-16-2006, 08:25 PM   #262 (permalink)
boostking's Avatar
Member Number: 25195
If anyone wants to buy a boost leak tester, i can make you one..just pm me
boostking is offline   Reply With Quote
Old 08-18-2006, 09:25 PM   #263 (permalink)
riceisnice's Avatar
Bump it up anyone have any ideas where the hell the boost is coming from?
Old 08-19-2006, 08:46 PM   #264 (permalink)
croy75's Avatar
Member Number: 3006
Anybody timed their boost leak test? I timed mine:
20psi to 15psi: 20sec
15psi to 10psi: 30sec
10psi to 05psi: 45sec
05psi to 00psi: +3min
from 20psi to 5psi: 95sec
croy75 is offline   Reply With Quote
Old 08-25-2006, 06:11 PM   #265 (permalink)
GOTNEON's Avatar
Member Number: 7925
Trader Rating: (12)
Thumbs up Car is perfect now
No more leaks. Peaks 19 and holds 18-19 on stage 2. Found my 5psi leak at brake booster where boost gauge hooks up to.... capped it and hooked up mopar electronic boost gauge. Also in past found huge leak between TB and spacer. Used black seal tack rated for up to some insane psi number and new gasket. Still no leaky.
Mods:ASA17x7.5Rims,225/45/17XL Eagle F1,K&N CAI,DCR 55mmTB,Beast FMIC,Greddy Catchcan,Mopar 7.5mm Plug wires,NGK plugs,Mopar Hp clutch,
S2 no toys,MF 3"O2pipe,Mopar Catdelete,borla catback w/AERO Turbine Muffler,filled mm's and tran mount,Mopar A/F,Oil,volt and 30psi gauges, MoparSTS,Booger bushings,Mopar S3 coilovers, front/rear strut bars,Mopar rear tension endlinks,22mm rear swaybar,26mm front swaybar,ES LCA bushings,Bwoody H-Brace,SBR crash bar
GOTNEON is offline   Reply With Quote
Old 09-18-2006, 07:45 PM   #266 (permalink)
Member Number: 44655
hey guys...i need some help... i just got my srt-4 about 2 months ago and an AGP wga was already on...that and a mopar BOV, i still have stock pipes but buying AGP hardpipes verysoon... well when i drive my car it doesn't really spike...it just hit 11-12psi and stays when i'm punchin it...then this weekend i drove a friends and realized...his actually spikes...it hit 15 then feel to 13...so i'm guessing its a boost leak?...any suggestions? and i need a tester...anyone?
Socboy3000 is offline   Reply With Quote
Old 09-19-2006, 01:19 AM   #267 (permalink)
arlo's Avatar
Member Number: 40243
Make sure you are running the best gas you can hi octane from a good place! then clear the ecu (unhook the battery for a bit) and try again. the ecu learns the boost the waste gate actuator runs at and relearns how to control it if, it can (especialy if you are getting any knock!) then of course do a boost leak test you can almost alway find little leaks!
arlo is offline   Reply With Quote
Old 09-19-2006, 09:55 AM   #268 (permalink)
thanx for tha feedback yo....i'm desperate!!! I mean come on ...i lost to A Mustang GT and RSX this weekend...i'm putting these SRT's to shame!!
Old 09-19-2006, 10:07 AM   #269 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
What are the mods?
hemidakota is offline   Reply With Quote
Old 09-19-2006, 01:02 PM   #270 (permalink)
well i tried diconnecting the battery for about an hour and no change really...i felt laybe a lil more power/pull but that could be just in my head....Mods=AGP wga, Borla Exhaust, MSD wires and coils, Iradium plugs,Purple royal synthetic oil, Mopar cai,Mopar BOV, and i'm installin my needswings dp today...
Well when i got it used(50,000 miles on it) a day after my hot side pipe poped off and i couldn't get it back on due to lack of tools...so i paid a machanic to do it....and it still look a ok so i guess boostleak test is the way to go?
» Sponsor Links
»Garage Storage and Cabinets
