Old 05-22-2006, 04:52 PM   #1 (permalink)
Member Number: 18115
Default Boost Gauge wiggle ??????
ok ever since I have had my CSPP my boost gauge will hit 17-20lbs and it bounces back and forth really bad. It does it in first and second too, It looks like it maked the proper boost it just bothers me cause the needle used to just peg 17 and go to 15 at redline, now it bounces, any one else have this problem????
Thanks
mods: stage2 w/o toys, B&B turbo back, AGP mounts,Greddy type RS BOV,JMB CPP & MISC.....
Bofus is offline   Reply With Quote
Old 05-22-2006, 04:58 PM   #2 (permalink)
04PAcruz'n's Avatar
Member Number: 8512
Thanks
yes! its a leak from somewhere. I've had this problem since I installed S2. tightened hoses, got a boost leak check and it still does it. I am going to lower my plug gap to .35. (maybe spark blow-out) and I also ordered a check valve to see if that will help. I will let you know.
Mods:
S2 w/o, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Mopar TB Exhaust (cat-back+cat-delete), Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV,4306 NGKs, JMB catchcan, Pwerks grounding kit, PTP check valve
04PAcruz'n is offline   Reply With Quote
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.15274 seconds with 13 queries
