Old 10-27-2009, 01:51 PM   #1 (permalink)
Member Number: 72243
Default Blow off valve problem?
So this problem just starting happening a few weeks ago but i never really wanted to do anything about it until now, what will happen is normally i would hear only my blow off valve when im shifting but now ill hear my blow off valve and then ill hear my waste gate flutter after. any input on how to fix this would help alot cuz its really annoying me.
blackconblack is offline   Reply With Quote
Old 10-27-2009, 11:41 PM   #2 (permalink)
bump for the night
Old 10-29-2009, 11:15 PM   #3 (permalink)
bump again, any input would help
Old 11-05-2009, 11:20 AM   #4 (permalink)
Member Number: 75196
take your Surge valve off, there might be a tear in the rubber or might even be a broken bolt on the valve to the turbo(<---had that happen)
wjwarmy80 is offline   Reply With Quote
Old 11-05-2009, 11:56 AM   #5 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Is this at partial throttle? If you let off the gas at partial throttle boost or just unboost but remain accelerating some you will get some compressor surge. It's not that bad though. It's only if every time you blow off you get that noise that it's bad. Check your vac lines and make sure everything is hooked up right, and you may want to check the turbo play, the turbo may be on the way out.
Page generated in 0.12566 seconds with 13 queries
