Old 07-15-2008, 02:15 AM   #1 (permalink)
Member Number: 26683
Default a bit confused:(
Well i recently got done reinstalling my engine after haveing a valve job done due to a blown turbo, and i can get it to fire up, i got gas and spark, but no fire, i checked my plugs there all gapped to around 35 and all my grounds are good, it sounded like it wanted to try to start once, but now it wont, it just turns over and over. Any ideas, Also does anyone know what would cause a battery to constantly being drained? or the plastic cap to melt due to it getting hot? i think its getting shorted to ground but i cant find it anywhere. Any help would be appreciated thank you.
Floner is offline   Reply With Quote
Old 07-15-2008, 05:42 AM   #2 (permalink)
slyder's Avatar
Member Number: 36768
Trader Rating: (67)
/\ it almost sounds like your timing is off.
/\ you have a short plain and simple especially if you are melting your battery
Check all your wires, when you set the engine in you might have pinched something cutting the insulation and shorting out
GL,
Slyder
slyder is offline   Reply With Quote
Old 07-15-2008, 11:12 AM   #3 (permalink)
GL,
Slyder
Thank you ill check it out...upon further investigatin i now found i have extremely weak spark sometimes no spark looks like its a coil pack i have 10V going into the coil, does anyone have a link to a schematic on our car?
Page generated in 0.12509 seconds with 11 queries
