Old 03-29-2006, 10:41 PM   #1 (permalink)
mustangdude20's Avatar
Member Number: 34496
Default BIG PROBLEMS need help diagnosing
hey guys big problems with the car right now when it warms up and i step on it it just stutters and doesn't really move and BILLOWS white smoke
currently Evilcreations "lacky"
my oil lines are more coked up then a stripper at scores!!! shit rick james ain't got nothin on me!
mustangdude20 is offline   Reply With Quote
Old 03-29-2006, 11:01 PM   #2 (permalink)
turboweasel24's Avatar
Member Number: 23118
sounds like u eather have a blown head gasket or messed up a piston ring
turboweasel24 is offline   Reply With Quote
Old 03-29-2006, 11:17 PM   #3 (permalink)
ya from what i've heard its the head gasket gonna pull the lower coolant hose and inspect for oil (fingers crossed)
Old 03-30-2006, 03:06 AM   #4 (permalink)
Member Number: 5369
If a head gasket goes out it will not always cause water and oil to mix and vice versa. It's possible for it to leak between cylinders, develop external leaks, or burn coolant or oil. What type of things have you been doing to the car that could cause a head gasket problem? Also have you pulled the spark plugs to see how they look? You can tell a lot by checking if they're oily, have rust on them, etc.
Old 03-30-2006, 03:25 AM   #5 (permalink)
Vector's Avatar
Member Number: 4644
Trader Rating: (24)
one thing you can try is while the car is running pull 1 wire at a time
if the car changes dramaticly you can tell where you might have a problem'
what did you do to mess up a head gasket
Vector is offline   Reply With Quote
Old 03-30-2006, 03:42 AM   #6 (permalink)
Member Number: 11681
Trader Rating: (96)
Also if it mixes usually your oil is white and milky
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
Old 03-30-2006, 07:40 AM   #7 (permalink)
Member Number: 37135
you need to check compression and pressure test radiator/coolent system. if you dont know how to do it take it to a qualified mech.
fatman is offline   Reply With Quote
Old 03-30-2006, 12:54 PM   #8 (permalink)
getting ready to drain coolant today and perform a compression test i'm fairly certain its the head gasket as its all the normal signs of it i was just so panic'd yesterday i started asking for help from everyone everyone that's had one go said mine sounds the exact same as when it happened to them
cause my car has been running extremely warm and i added some coolant but i suspect then along with a slight detonation problem due to a faulty regualtor i was using pushed it past the limits
Old 03-30-2006, 12:55 PM   #9 (permalink)
on the bright side i was planning to put a ported head and custom intake manifold on in the next couple of weeks as well as a turbo swap so its just gonna happen sooner now
Old 03-30-2006, 01:09 PM   #10 (permalink)
nevermind i just pulled the plugs they were covered in oil
looks like i'm building the motor too
Old 03-30-2006, 09:44 PM   #11 (permalink)
haha figured it out my turbo seals and bearings are SCREWED thank god its an easy fix
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.19895 seconds with 13 queries
