Old 05-06-2008, 12:34 PM   #1 (permalink)
DutchSRT4's Avatar
Member Number: 22330
Default Backfire Problem :(
Hey guys, all of a sudden my car is starting to misfire only when at full boost, almost sounds like its backfiring through the intake. When idling or just putsing/cruising on the highway it runs 100%. I think that it may be a WGA problem. All vacuum lines are good, plugs are good and so are the wires. I have the AGP w/g (about 90000kms on it). The car has always had really bad Part throttle boost, and the misfire is the worst when in PTB, but still does it under full boost. Any help would be great, thanks guys.
Commemorative Edition #84
Stage 1, Perrin 3"turboback, AGP WGA, AGP CAI, AGP hardpipes, AGP dogbones, Mopar BOV, MSD coil and wires, AEM UEGO, mapclamp, Eibach Pro kit. Vac line mods.
DutchSRT4 is offline   Reply With Quote
Old 05-06-2008, 12:42 PM   #2 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Spark plugs or fuel cut.
HCCAFan is offline   Reply With Quote
Old 05-06-2008, 12:45 PM   #3 (permalink)
missionsk8r21's Avatar
Member Number: 56407
Trader Rating: (21)
try running the stock coil and wires with sum ngk's/champion plugs gapped @ .35. I had the same problem and that fixed it.
05 ACR - Full bolt-on SSTv2.5 - SOLD
Current:
02 WRX with STI swap + 20g turbo + bolt-ons
02 GSX-R 600
missionsk8r21 is offline   Reply With Quote
Old 05-06-2008, 12:53 PM   #4 (permalink)
DutchSRT4's Avatar
Already tried changing the plugs and the wires, even switched out the coil to check that. All checked out good. Gap is at .045, so I will try .035, and they are Champion Iridiums.
Old 05-06-2008, 03:08 PM   #5 (permalink)
DutchSRT4's Avatar
Re-gapped them and the problem is gone, thanks for the help guys!!!
Old 05-06-2008, 06:17 PM   #6 (permalink)
Member Number: 53402
just curious what were they gapped at before you changed it?
orangesrt-4 is offline   Reply With Quote
Old 05-09-2008, 06:21 PM   #7 (permalink)
teufelhounden91's Avatar
Member Number: 46085
wait you gapped irridiums? I just had a huge convo w/ the guy at pepboys on how important it is to NOT gap irridium plugs...ever. He said "you're never supposed to touch the gap of an irridium plug, or they wont work." Factory comes at around .042 and needs to stay there. Is this true? I want to bring mine down to .035 but now Im afraid to.
teufelhounden91 is offline   Reply With Quote
Old 05-09-2008, 09:27 PM   #8 (permalink)
first mistake: Auto parts suppliers usually don't know crap! That guy is an idiot. if you up the boost you should gap them smaller, but i stay with in the specs of stage 2 requirements. I think its .032-.036 if you gap them smaller you will burn them out faster but if you are not stock boost levels then you will have to play around till you get them dialed in.
Old 05-09-2008, 09:38 PM   #9 (permalink)
lol, thanks for the smack in the head! I just gapped mine from .046 to .035 and im actually HOLDING BOOST!!!!! Crazy! Stock, I peak 16, and hold 14-15 to Fuel Cut-off.
Im gonna go to Pepboys and slap that mo-fo!
Old 05-09-2008, 11:56 PM   #10 (permalink)
shadowsz's Avatar
Member Number: 55920
..the guy at pepboys tried to tell me that a 3 ton engine hoist wouldnt hold an engine...
Phase 4 of 17 at the Universal Technical Institure. Getting to meet some of the dumbest people I have ever met...
shadowsz is offline   Reply With Quote
Old 05-10-2008, 09:41 AM   #11 (permalink)
hahaha! was he trying to sell you a 10-ton hoist instead? theyre really good about listening to your needs, and trying to upsell the sh*t out of you. I bought a tube of gasket silicone for the block plate I put on the turbo. He said a small 0.5 oz tube wasnt enough, and that i needed a 1.5 oz for 3x the price. I laughed at him, and bought the small one and after generous use there is still 90% of the tube left. Jerk-off!
Old 05-10-2008, 01:15 PM   #12 (permalink)
What! there should be atleast 98% left in that tube
Page generated in 0.20232 seconds with 13 queries
