Old 11-06-2009, 01:35 PM   #1 (permalink)
lil_hub_cap's Avatar
Member Number: 75014
Default Another srt problem.
Well i had thought i fixed my cars problem as it was throwing a couple differant codes. I replaced the 02 sensor, only to later on get a MAP code thrown at me. P2074, after looking into it a but heavily, i volt tested the bulk head into the map, and had 4.88 volts going in. On the output side it was only reading 1.68v with key on. the bulk head and wires are fine, ive already checked the whole wire setup, the only thing i can figure is the map is gone bad? does this all sound about right?
I have a 3 bar map sensor just not installed, is all i need to do to instal it tune it with a dsp and call it good? or is there something more i would need to purchase?
thanks
lil_hub_cap is offline   Reply With Quote
Old 11-06-2009, 01:38 PM   #2 (permalink)
diznan88's Avatar
Member Number: 60323
Have u tryed measuring the voltage wile having someone rev the motor it should change with air flow if not I would say it's bad just my 2 cents.
diznan88 is offline   Reply With Quote
Old 11-06-2009, 02:11 PM   #3 (permalink)
i cant say ive tried that. once i get a chance, ill see if i cant get a friend to help me check that.
Old 11-07-2009, 06:20 PM   #4 (permalink)
bump.
Page generated in 0.19957 seconds with 13 queries
