Old 07-21-2008, 11:27 AM   #1 (permalink)
Member Number: 211
Default Abs Lght...
ABS light came back on thought It Was the brake fluid cause It looked low.fill It back to level.Stayed off for a bit now Its back on.no codes.What else to look for?Thanks In advance.
SRT4PWR is offline   Reply With Quote
Old 07-21-2008, 12:01 PM   #2 (permalink)
SRToc Member
04srt4black's Avatar
Member Number: 22206
Trader Rating: (157)
Bump , my ABS light is on too and no codes , Damn neons haha
I filled mine up with fluid , checked the fuse , bleed the brakes and its still on . I have no clue either .
*Need Srt4 Parts ? ? ? ? , PM ME !!*
08 Caliber Srt-4 (under construction )
Sponsored By Darksyde Innovations , Pm darksyde For Amazing Port Work and Powder coating
04srt4black is offline   Reply With Quote
Old 07-31-2008, 01:10 PM   #3 (permalink)
Member Number: 65244
mine just came on too. Has anyone figured it out yet?
lpetters is offline   Reply With Quote
Old 07-31-2008, 01:16 PM   #4 (permalink)
thttxboy's Avatar
Member Number: 44679
check Your Abs Sensors on the front knuckles or all of them. I had a friend of mine whos light was on and all It was that when his axel leaked it got on the sensor and had to be cleaned. never came on after that.
thttxboy is offline   Reply With Quote
Old 08-01-2008, 01:11 PM   #5 (permalink)
my light comes and goes. Where are these sensors located again?
Old 08-01-2008, 02:24 PM   #6 (permalink)
SRToc Member
^They are in the spindle/hub . all 4 corners have them . Its a 10mm bolt holding them on .
I know i mine the drivers side when i changed out spindles was hard to plug into , so that may be my problem , i just aint worried about that right now at the moment , lol .
Old 08-03-2008, 06:59 AM   #7 (permalink)
RSchyns's Avatar
Member Number: 2019
Trader Rating: (17)
If you dont see any damage with a visual inspection of the speed sensors, you will need to scan with the DRBIII. The ABS sensors are a scam on these cars, a big money maker for the dealer.
1 hr labor to scan with the DRBIII (takes 5 minutes) $85
New speed sensor $60
1 hr labor to install sensor $85
Your almost better off buying the two front sensors from S&P and swaping them out yourself. You have a 50/50 shot at fixing the bad sensor for about $110. If that doesnt do it, buy the back two. Should cost you less than the dealer doing one sensor. And the upside is that you will have all 4 new sensors.
I found someone local who scanned the car for me.
Good luck
RSchyns is offline   Reply With Quote
Old 08-04-2008, 03:51 PM   #8 (permalink)
Member Number: 211
Default cool.
Thanks dudes.Sounds good.
Page generated in 0.15975 seconds with 11 queries
