Symptom List:
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P1696-EEPROM MEMORY
WRITE DENIED/INVALID.
When Monitored and Set Condition:
When Monitored: With the ignition on continuous.
Set Condition: An attempt to program/write to the internal EEPROM failed. Also checks
at power down.
Set Condition: An attempt to program/write to the internal EEPROM failed, Also checks
at power down.
POSSIBLE CAUSES
DRB DISPLAYS WRITE FAILURE
DRB DISPLAYS WRITE REFUSED 2ND TIME
DRB DISPLAYS SRI MILEAGE INVALID
COMPARE SRI MILEAGE WITH ODOMETER
TEST ACTION APPLICABILITY
1 With the DRBIIIt, perform the SRI Memory Test.
Does the DRBIIIt display Write Failure?
All
Yes ! Replace and program the Powertrain Control Module in accordance
with the Service Information.
Perform POWERTRAIN VERIFICATION TEST VER - 1.
No ! Go To 2
2 With the DRBIIIt, perform the SRI Memory Test.
Does the DRBIIIt display Write Refused?
All
Yes ! Go To 3
No ! Go To 4
277
DRIVEABILITY - NGC
3 With the DRBIIIt, perform the SRI Memory Test a second time.
NOTE: Retest the SRI Memory two more times.
Does the DRBIIIt display Write Refused again?
All
No ! Test Complete.
4 With the DRBIIIt, perform the SRI Memory Test.
Does the DRBIIIt display SRI Mileage Invalid?
All
Yes ! Update the mileage and retest the SRI Memory.
No ! Go To 5
5 Compare the SRI Mileage stored with the Instrument Panel Odometer.
Is the mileage within the specified range displayed on the DRBIIIt?
All
Yes ! Test Complete.
No ! Update the mileage and retest the SRI Memory.
278
DRIVEABILITY - NGC
P1696-EEPROM MEMORY WRITE DENIED/INVALID — Continued
