Old 10-29-2009, 05:30 PM   #1 (permalink)
Member Number: 59653
Default 95 SRT-4 Swap Done but Help
Hello i have a 1995 dodge neon with SRT-4 Swap. but here is my information and need help ASAP.
Well i made a post before and didnt get any where lol. But here is my problem i have a 1995 2.4 Swap with SRT-4 Internals and turbo and all that. I had to retime it becuase it skipped a tooth or more witch it did. Had a code 11 witch i fixed and its gone. But when i go to start it , it will start and try to stay running and then die after 5 seconds after i start it. Then some times it wont want to start but it cranks . Someone told me it could be a bad Crank sensor. But i think its something else. Anything i can check before going into the motor and flipping out haha. But please help me out its making me mad.
the only codes i got is:
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles
55 End of error messages (If you get this only, no errors were found)
thats it. I need your pro help.
YouTube - Help need a car ASAP
Neon.org Post i made:
www.neons.org • View topic - Starts then dies after 5 seconds or dont start.
Thanks everyone
~Cody.
2.4 Motor in 1995 dodge neon.
dtecneon is offline   Reply With Quote
Old 10-29-2009, 05:47 PM   #2 (permalink)
lbrmotorsports's Avatar
Member Number: 32370
Thanks everyone
~Cody.
2.4 with srt pistons and turbo dosn't mean srt swaped. So is it a 2.4 n/a , with turbo you are running. What computer and so on. All this might help you out if you tell.
lbrmotorsports is offline   Reply With Quote
Old 10-29-2009, 06:10 PM   #3 (permalink)
well motor is built For SRT-4. yes its N/A 2.4 Not a srt4 motor but i built With srt4 internals.
SRT-4 Pistons,
SRT-4 Cams and Cam gears.
SRT-4 Turbo and Manifold
Stock 95-99 DOHC Intake manifold. Only one the head would work with.
95 dodge neon ECU ( DTEC FC,BC ) Tuned !!!
Running 14 PSI.
SRT-4 Injectors ( 03 ) i think the purple ones.
i added the Youtube video above. i hate trying to do a video and while your fucking sick lol but o well its up there ^^^^
Old 10-29-2009, 06:20 PM   #4 (permalink)
Mopar3R's Avatar
Member Number: 73994
Is your PCM made for a DOHC engine?
Mopar3R is offline   Reply With Quote
Old 10-29-2009, 06:27 PM   #5 (permalink)
yes its a 95 DOHC ECU.
Old 10-29-2009, 06:37 PM   #6 (permalink)
Member Number: 64577
My car did the similiar thing and it was a bad cam position sensor. The car would start-barely, and it would run like shit, if I gave it gas it wouldnt go past 2500.
STILL GH3Tt0 is offline   Reply With Quote
Old 10-29-2009, 06:45 PM   #7 (permalink)
ok well im going to a junk yard tomorrow and ill get one anything else before i go up and dont get everything. i need this car running soon. Thanks for the help. No one helps on neons.org haha.
anything else ?
Old 11-07-2009, 06:04 PM   #8 (permalink)
here is my videos i got my car going again
YouTube - help again
i just put new injector clips and it started up. But i dont know why it spudders and 1000,2000 grand it will spudder but if i rev past that it will not spudder. Once in a while it will start up spuddering but it will quit. I need help with this
ok i went to work on my car today and put more gas in it . then it wouldnt want to start. it would crank and try to start and die. Then my dad was telling me i should take the spark plugs out and dump gas in the spark plug holes. so i put everything together and it fired up. so i turned it off to see if it would start again and it will not unless you tap the gas and it will spudder then idle fine. then when i get to see if it spudders when i rev witch it dose. so i need your help please help me i need this running again. thanks.
Old 11-11-2009, 05:58 PM   #9 (permalink)
Car is running fine Now !!! Thanks everyone who helped me out I put new spark plugs in and gaped them to SRT-4 specs for the boost setting and Timing is right and everything thanks once again.
Page generated in 0.14153 seconds with 13 queries
