Old 10-11-2006, 11:20 AM   #1 (permalink)
nick0716's Avatar
Member Number: 8693
Default #3 cylinder siezed?
the dealer said my no. 3 cylinder seized. they said i need a new shortblock and im looking at 3900.00 for this i dont know much about cars but why cant they just fix the cyinder? Im so confused and i cant afford 4k does anyone have any suggestions? thanks ahead of time. nick
nick0716 is offline   Reply With Quote
Old 10-11-2006, 11:25 AM   #2 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
Most of that quoted amount is labor... If they fixed the cylinders (they would all need to be worked on) versus giving you a new shortblock, it might save you $300-$500, maybe.
Look for a local shop you can trust to do the work and just buy a shortblock from the dealer or a used engine from a salvage yard.
Old 10-11-2006, 11:27 AM   #3 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
Also....why did it seize? That should be the big question.
Old 10-11-2006, 11:27 AM   #4 (permalink)
SRT4Quagmire's Avatar
Member Number: 32324
Trader Rating: (106)
The cylinder wall is part of the "short block" (bottom of your motor) they probably cant hone out the cylinder due to the piston being stuck at an obtuse angle in there or it put a hole in the wall.
You could look in the buy sell section for a short block and save some dough, you most likely will need a new set of pistons. I wonder what the hell you did to your car for this to happen tho.
I take it your warranty is shot or you didnt get the transferable 7/70 like us '03 owenrs did.
Good luck, and thanks for making me laugh at your misfortune.
SRT4Quagmire is offline   Reply With Quote
Old 10-11-2006, 11:42 AM   #5 (permalink)
nick0716's Avatar
Member Number: 8693
first my mods, wga set to 15, stage 1 and cai.
I heard a faint ckicking noise after i put it into second instead of 4th
back 5 months ago and it never went away.
2 weeks ago my shifter block seized it was covered under warranty
Got it back the noise is so much louder, {clicking under low acceration}
took it back in thinking they could fix it, they can but not under warranty due to my street racing setup of cai stage 1 and wga.
1#
how much will i save if i get the parts online here and have it installed at a local shop?
2#
does a short block come with all the local shop needs for this or do i need the dealer to give me list of all the crap i may need?
thanks again for responding so quick
Old 10-11-2006, 12:03 PM   #6 (permalink)
nick0716's Avatar
Member Number: 8693
also one more thing.
how long can i drive on it since i cant afford 4k now?
it shouldnt make it any worse since i need a whole new block right?
Old 10-11-2006, 12:25 PM   #7 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (48)
so you had tried to shift into 4th at like 3k and missed, or were you accelerating hard and tried to shift at 5k? If you overrevved your engine, then it's possible that your bottom end MIGHT be ok, but the vavletrain may be shot.
*This is just my casual observations*
My recommendation is to get a 2nd opinion from a performance shop that is close to you.
$.02
a853rox is offline   Reply With Quote
Old 10-11-2006, 12:34 PM   #8 (permalink)
Member Number: 14585
Trader Rating: (19)
Brand new shortblock from s&p is 1000. Installed probally another 600.
bigdoggsrt4 is offline   Reply With Quote
Old 10-11-2006, 03:47 PM   #9 (permalink)
nick0716's Avatar
Member Number: 8693
bump...
Old 10-14-2006, 01:43 AM   #10 (permalink)
nick0716's Avatar
Member Number: 8693
UPDATE:
i want to fix it myself, dealer offered me 8500 for it and it only has 20k on it, (so no)
does anyone know what happens if i drive on it since i already fucked it up can i cost myself more damage?
Old 10-14-2006, 02:06 AM   #11 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
"took it back in thinking they could fix it, they can but not under warranty due to my street racing setup of cai stage 1 and wga."
Wow, they called that a street racing setup? Did you tell them you were at high rpm's and went from 3rd to 2nd gear? That would screw you right there. It would be simple to put it back to stock and take it to a different dealer. Unless they flagged you on the system. You won't ever know unless you try.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 10-14-2006, 02:11 AM   #12 (permalink)
nick0716's Avatar
Member Number: 8693
they said they put it in the computer and i cant sell it anywhere..
Old 10-14-2006, 06:58 AM   #13 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
They are trying to rape you. You can not drive the car at all if it has a siezed cylinder. The piston kinda has to move up and down for the motor to run. The easiest way to go about fixing it yourself will be to contact Jimmy at S&P performance and order up a short block for just under $1000. Tell Jimmy what you are trying to do and he will hook you up, and make sure you order all the parts that will be needed.
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 10-14-2006, 07:07 AM   #14 (permalink)
darrell cox's Avatar
Member Number: 35031
Trader Rating: (163)
I have complete new OE short blocks for $895.00 + shipping.
Darrell
Darrell Cox Racing
Team/Dodge/SRT/Mopar
darrell cox is offline   Reply With Quote
Old 10-14-2006, 07:25 AM   #15 (permalink)
Member Number: 39141
Damn good deal from Darrell Cox for 895.00 plus shipping for a complete block, awsome.. all you need to do is remove from car and re-assemble, install pan, head,manifold,etc.. just make sure your valve train is not messed up, take head to local machine shop for mild work and have them check it out..read a manual on how to prime oil pump, etc... get familiare with engine building. Good luck.
05 SRT4 'M' Stg 1 kit,Injen CAI,Forge bov, AGP Cc,PTP cv,PTP 180 Stat,MPX coil heatshield, wndw tint 20&35%, Mopar Frnt strut brace,Prothane MM inserts,Maddog 58 STS, Mopar stg 1 sways. NGK plugs, Mopar cat back, Weather-tech ventvisors.Mopar Perf.wires. Mopar 25mm drop springs.sway bar poly bushings. Nexo 17x7 NT5 wheels in Gunmetal, 225-45-17 Falken 452 tires, SS 14" antenna.More..
KEVS SRT4 is offline   Reply With Quote
