Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Automotosports
Old 05-11-2007, 10:59 AM   #76 (permalink)
srt4me18's Avatar
Member Number: 50825
so when are the 37r's coming back in stock??
hp61
AEM Ems, STock Head, Stock Cams, STock block
Aaronneon Tune=badass
60' 1.75
1/8 7.52@101.55
1/4 11.45@125mph
1.66 60' wasted on a 13.2@64mph
srt4me18 is offline
Old 05-11-2007, 10:59 AM   #77 (permalink)
srt4me18's Avatar
srt4me18 is offline
Old 05-14-2007, 08:41 AM   #78 (permalink)
Frank@AMS's Avatar
Member Number: 36761
We are expecting them in within the next 4 weeks.
AMS
"When you want the best"
www.amsperformance.com
frank@amsperformance.com
2442 E Oakton St
Arlington Heights, IL 60005
847 709-0530
Frank@AMS is offline
Old 10-23-2007, 12:10 PM   #79 (permalink)
Member Number: 43665
Quote: Originally Posted by AMS
OK guys here we go
Pricing is as follows:
AMS GT35R turbo kit with:
AMS 304 Thick wall SS header with 2 year warranty against cracking
AMS Spec GT35R Turbo w 4" ported Shroud
3" SS O2 Housing
Tial 38mm WG
SS Dump Tube
3" Stainless Steel downpipe with 3" 2 bolt flange
4" Alluminum Intake pipe with 4" k&N Intake
Oil and water lines
2.5" Lower IC pipe SS
All Couplers and hardware
All flanges are .5" thick SS to prevent any warping
Tig welding all around
$3899.95 Tentatively. we are working on some things right now to get it down a little bit but at most $200.00 cheaper. Keep in mind this kit only costs $150 less to make then the EVO VIII kit.... we are making VERY LITTLE on this piece.
GT3076R kits will be $100 cheaper
50 trim Ball bearing kits will be $200 cheaper
Silver high temp coating adds $150
Polished Compressor cover adds $100
Ordering right now is a MINIMUM of a 4 week wait. with at least 50% deposit due
we are going to build the kits to order at this time.
Not shown in the pictures: Lower IC Pipe, Oil Lines, water lines and 4 Intake pipe
Eric
i will be purchasing your kit within the next couple months and was wondering how much extra for the 37r kit. i will have the dcr 2.6 stroker so spool will not be an issue. any info you could give me would be great
05 BLACK NEON SRT-4 - Totalled
08 SILVER CALIBER SRT-4 - Still Breaking It In
AASLT_SRT4 is offline
Old 11-07-2007, 11:57 PM   #80 (permalink)
Member Number: 58212
If somebody hasn't already gotten back to you I'll find out tomorrow.
Nick S is offline
Old 11-10-2007, 10:00 AM   #81 (permalink)
The AMS SRT-4 Turbo Kit is $4094.95 with the option of either a GT35R OR an AMS37R. If you want a GT30R (3076) then the kit is $100 less.
Nick S is offline
Old 11-11-2007, 12:19 PM   #82 (permalink)
gq4life's Avatar
Member Number: 10297
Im guessing to really get the most out of AMS37R or even GT35R you need aftermarket heads, cams, valvetrains and raise REV Limiter up to 7K..
sounds like these turbos dont get full spool to after 4K RPMs
Really dying to see Dyno graph showin RPMs..
gq4life is offline
Old 11-12-2007, 07:31 AM   #83 (permalink)
That can be said of any turbo kit really. I'll see what I can find for a dyno chart.
Nick S is offline
Old 11-12-2007, 10:01 PM   #84 (permalink)
I'm sorry I don't have a full modification list for this car but it's from a black SRT-4 with our AMS GT37R Turbo Kit.
PUMP GAS
RACE GAS
Nick S is offline
Old 11-13-2007, 09:00 AM   #85 (permalink)
gq4life's Avatar
wow.. 772wHP and its stays over 700wHP from 5800rpm to 7K redline.. I hate when i see dynos and it just peaks like 400wHP but 1K rpms before its 100HP less..
nice dyno
thanxs
gq4life is offline
Old 11-13-2007, 09:05 AM   #86 (permalink)
gq4life's Avatar
by dyno graph.. we can assume modfications are alot..
gq4life is offline
Old 12-24-2007, 01:38 AM   #87 (permalink)
After doing a little bit of looking around on the forum here I believe this is what the car had:
Engine:
AMS Built Block-
Weisco Pistons
Oliver Rods
DCR Main/Rod Bearings
DCR Oil Pick up
DCR Billet Oil Pump Gear
DCR Baffle
DCR Bigger Oil Filter Combo
DCR Head Studs
O-Ringed Block
MADI Crank
AMS Build Race Head-
1mm Over Si Intake and Exhaust Valves
Crane Springs and Titanium Retainers
5 Angle Valve Job Unshrouded
Full Race Port
Cam Gears
Crower S3 Cams
DCR Top End Oil Modifier
Electronics/Ignition:
AEM EMS
AEM Injector Driver Box
AEM Wideband
Greddy Turbo Timer
Stewart Warner 40psi Boost Guage
MSD Dis-2 Ignition
Custom Taylor Plug Wires
Fuel:
Precision 1600cc Injectors
Dual Denso 190lph Fuel Pumps
-10an fuel line from tank to pumps
-8an fuel line from pumps to fuel rail
Aeromotive FPR
-6an fuel line from reg to tank
Boomba Fuel Rail
Intake/Turbo Setup:
AMS GT37R DBB turbo kit
Form and Functioned Ported Intake Manifold
60mm TB and Manifold Adapter
AMS Custom UPP with Tial BOV
AGP Race FMIC
Of course not everybody wants or needs this much power, that's why we have different turbos available for different goals.
Nick S is offline
Old 12-24-2007, 08:17 AM   #88 (permalink)
gq4life's Avatar
to think my goal was just 425wHP at 24psi on pump gas.. i feel like such an under achiever
gq4life is offline
Old 01-03-2008, 07:34 AM   #89 (permalink)
Member Number: 57123
Quote: Originally Posted by AMS View Post
OK guys here we go
3" SS O2 Housing
Tial 38mm WG
SS Dump Tube
Oil and water lines
Eric
Do fuel upgrades come with this kit?
up_in_boost is offline
Old 01-03-2008, 10:19 AM   #90 (permalink)
gq4life's Avatar
not according to that list.. price would go up..
this kit has a hard pipe, and downpipe which most kits dont..
this kit is worth it just to get their manifold with it..
gq4life is offline
Page generated in 0.23539 seconds with 11 queries
Search Engine Optimization by
