just wondering if anyone had a AMS shortblock and how much HP it makes. On top of that how much boost or power can it take as well? I'm really interested in this build-up, so leads maybe helpful. Have a totally stock Stg3R w/ toys if interested in my mods. Future might want to run a good 75 shot with ported intake mani & 55mm TB...
yea i saw that vid after surfing on the forums, that was very impressive. well we know now power can be handled with that block. one question left, what about HP gains? i'm thinking of a .020 or .040 overbore w/ the ARP head stud option on that block.
Slim to none. Double check with AMS but I'm almost 100% positive they overbored the blue car and didn't see any gain. I'm not sure about 4U2NV's set-up though.
Going twenty or forty will not show any noticeable gains. The main reason why most four cylinder cars go overbore is to clean up any imperfections in the side wall of the cylinder. To pick up displacement with cars like ours, you?d need to modify the stroke.
AMS
"When you want the best"
www.amsperformance.com
frank@amsperformance.com
2442 E Oakton St
Arlington Heights, IL 60005
847 709-0530
plus if your gonna put in aftermarket pistons too right?
[IMG]<a href="http://photobucket.com" target="_blank"><img src="http://i49.photobucket.com/albums/f284/seansurfn2/RFR2cars.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>[/IMG]
correct. My car is a stock bore car with wisecos. Started with a brand new shortblock from dodge and built that. Also went up on the compression just a bit too, so that helps. These are turbo cars though, so you're mainly building the motor to throw more boost at it and stay together
I blew up my engine so I want to buy an AMS short block but i dont know how its going to work the stock turbo with the built block. Any ideas on how will this work?? will I feel the difference with the built bottom end? how many psi can I boost with the stock turbo so I will max it out??
What about stock turbo built block and NOS (100shot+) Please feel free to post any ideas , experiences... or whatever you think its important I should know.
BLACK 05 SRT 4--- Stage 1, AEM SRI, Greddy profec B spec II, AGP WGA, 3 inch turboback exhaust, UPP + HKS BOV, AGP Lower intercooler pipe, Quickwhips IC, MSD wires and NGK 4306's @ .30, AGP Fuel Return kit, SAFCII, MSD TACH, WALBRO 255 fuel pump, AGP motor & tranny mounts & a solid tune from Lujan Motorsports.!
We run stock timing belts and oil pumps.
We have not seen any problems with them.
As far as we know the eagel/weisco setup can hold about 600whp.
with continues beating the stock oil pump gears will break down and then the motor will fail due to oil pump failure. get the billet gears from dcr and you will be fine.
