Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT / Mopar / SRToc / Nationals Discussion > SRT Engineer Q/A Area
Closed Thread
Old 02-19-2007, 07:26 PM   #1 (permalink)
SRTforums Admin
JayC's Avatar
Member Number: 7619
Default SRT Chat Session - SRTForums.Com 2/21/2007
The next SRT Engineering chat session is scheduled for Wednesday, February 21st.
The session will run from from 6pm to 8pm EST and will be at SRTForums
Join us!
JayC is offline
Old 02-21-2007, 03:50 PM   #2 (permalink)
Member Number: 27628
Quote: Originally Posted by TSB
TSB #: 21-020-06
Date: December 20, 2006
Subject: Flash: SRT8 - Delayed Or Rough 1-2 shift at Wide Open Throttle After Kickdown
Overview: This bulletin involves selectively erasing and reprogramming the Transmission Control Module (TCM) with new software.
Models: ALL 2005-2006 SRT8 models of the 300C, Charger, Magnum and Grand Cherokee (North America and International Markets).
Symptom/Condition: The customer may experience a delayed 1-2 shift at wide open throttle after a kickdown. This is often referred to as a harsh or jerky shift which is the result of the engine reaching the maximum engine speed fuel cut off prior to the transmission shifting.
Note: This flash will also change the strategy for the ?Autostick? feature. This version will allow the transmission to upshift when the maximum engine speed is reached. The previous version would not allow the upshift unless the driver selected the next gear. Once the flash is performed, all of the changes are permanent and cannot be reversed.
Can you tell us what are the technical/logic changes to transmission behavior in the SRT-8's with this new TSB?
For example: ESP ON - will this now force a shift at 3200 if wheel spin is detected? Will it force a shift with ESP off if wheelspin is detected?
In Drive mode, what rpm will shifts happen under WOT? Is it different if in paddle mode (1-2-3-4-5)?
What changes cause the firmer-feeling shifts? Is torque management logic changed? If so, what changes?
Thank you for any insights you can provide.
JMatt is offline
Old 02-21-2007, 04:07 PM   #3 (permalink)
whiskey's Avatar
Member Number: 38628
Is the 1-2 shift problem noted in the LX platform also linked with the shifting problems noted in the Jeep SRT8?
2006 Dodge Charger SRT-8
2007 Grand Cherokee SRT-8
"Just because (you know) you're paranoid, don't mean they're not after you" -K. Cobain
whiskey is offline
Old 02-21-2007, 04:09 PM   #4 (permalink)
Hemi31's Avatar
Member Number: 51290
I noticed the center bearing on the driveshaft of the SRT8 LX's seems fairly light duty..Any idea what it's rated for before failure?
Hemi31 is offline
Old 02-21-2007, 04:11 PM   #5 (permalink)
Member Number: 51298
Hi i would like to know why i have a terrible up shift problem with the new TCM flash is the car spins it will force the up shift at 3200 rpms evertime it goes into second and Bogs down...It never did this before i had the Flash...the autostick works fines i have no more shift hesitation but WOW the upshift is terrible when you break the tires loose in 1st gear the car is a sled now What can be done to fix this problem Please help........
MY HEMI is offline
Old 02-21-2007, 04:15 PM   #6 (permalink)
Super Moderator
glhs837's Avatar
Member Number: 215
Hi Guys, two for you tonite
Scantools have shown less than %100 throttle position, even at WOT, is that real or an artifact of the data?
Why would I not see %100 calculated engine load until over 50 mph?
glhs837 is offline
Old 02-21-2007, 04:16 PM   #7 (permalink)
Super Moderator
glhs837's Avatar
Member Number: 215
And SRT-8 guys, we've now asked the 3200RPM question twice, give them a chance to answer.
glhs837 is offline
Old 02-21-2007, 04:17 PM   #8 (permalink)
SRT Engineering Team
Member Number: 34997
Don't let the looks deceive you, we have done extensive testing and it will be fine......
SRTengineers is offline
Old 02-21-2007, 04:18 PM   #9 (permalink)
Member Number: 36199
Given that the Drifting Charger has the 392 in it and a 6 speed, what are you all using for an PCM on that motor ? The Crate Stand Alone or something else ? Can you give up any more details on how the engine is set up ?
Also wondering about racing parts for these new hemi engines. Is there an active program for producing Racing HD parts for the 5.7 / 6.1 based motors.
Thanks
-Robert
RobAGD is offline
Old 02-21-2007, 04:20 PM   #10 (permalink)
Wait one guys. We just sent two guys out to do burn outs, we will be right back.
Old 02-21-2007, 04:21 PM   #11 (permalink)
Super Moderator
glhs837's Avatar
Member Number: 215
Just a quick reminder, dont bother with future product questions, they cannnot answer them. And no, thats not for you Rob
glhs837 is offline
Old 02-21-2007, 04:22 PM   #12 (permalink)
Thanks
-Robert
It has the new Mopar ECM. It's now shipping with the 392 crate engine and should be available as a stand alone shortly.
Old 02-21-2007, 04:23 PM   #13 (permalink)
Member Number: 1536
Reading up in the Factory 2006 LX Service Manual. I notice that the transmission Temperature is monitored. With a software change would it be possible to display this reading in the EVIC. Even if only in the "Engineering Mode". I mean we can monitor our left and right gas tanks and our auto headlamp light sensors.
Knowing what my tranny temp is when I am on a road race course would be a very nice addition. My car is a 2007 Magnum SRT8.
thanks
grey lupus is offline
Old 02-21-2007, 04:23 PM   #14 (permalink)
OK it does it in any ESP mode off or on if it breaks the tires or spins it will force the upshift at like 3200 RPM's i have done it everytime i tired to take off Hard it does this since the new TCM.....Hope you have one SRT there that does this..some do some dont......
MY HEMI is offline
Old 02-21-2007, 04:23 PM   #15 (permalink)
Thanks
-Robert
As for thr racing parts, we're working on some stuff ......
Closed Thread
