Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT / Mopar / SRToc / Nationals Discussion > SRT Engineer Q/A Area
Closed Thread
Old 12-07-2005, 06:48 AM   #46 (permalink)
xeo
xeo's Avatar
Member Number: 21111
Someone probably already knows this or has a copy but i would like to see a compressor map for the stock turbo, as well as know what is the most efficient boost level to run it at. Reading on here it seems 20 is max, but is it max because compressor efficiency drops off or is 20psi just what the turbo housing will allow?
xeo is offline
Old 12-07-2005, 09:15 AM   #47 (permalink)
Member Number: 17795
Quote: Originally Posted by robbie8302
Cruise control was on the SRT concept vehicle, but was not put in to production. I understand that you wanted a fast economical car, but why skimp on a popular item like this?
Mopar Speed Control Systems are designed to maximize your driving comfort, especially on long trips. Easy-to-use push-button resume, acceleration, set and coast controls. Identical to O.E. systems.
Add Part # Description Price
82208100AB For 2.0-liter engines, complete kit $235.00
This says for 2.0, but I heard it fits our cars
(1)Servo Connecter is not on vehicles built between 3/20/2003 and 3/12/2004. Check for presence of servo connector before ordering or installing. Do not attempt to install on vehicles built without it.
navysrt is offline
Old 12-07-2005, 09:24 AM   #48 (permalink)
Member Number: 13336
Trader Rating: (29)
According to that my car does not have the Servo Connector and I'm not to install that cruise with out it... So this does me no justice... It also doesn't answer the question as to why they didn't put it on the car, let alone even make it an option.
robbie8302 is offline
Old 12-07-2005, 12:37 PM   #49 (permalink)
Member Number: 18115
does it matter what kind of brake fluid do I use? Is there a special mopar brand.
mods: stage2 w/o toys, B&B turbo back, AGP mounts,Greddy type RS BOV,JMB CPP & MISC.....
Bofus is offline
Old 12-07-2005, 03:46 PM   #50 (permalink)
FranknBeans's Avatar
Member Number: 9927
see owners manual... should say there.
2003 Silver Dodge Srt-4 - sold
2007 Silver Dodge Nitro
2010 2SS Camaro
FranknBeans is offline
Old 12-07-2005, 06:45 PM   #51 (permalink)
eric_t12's Avatar
Member Number: 25803
Default SRT-4 (Caliber Questions)
What do you think will be the 2 best points of this new Caliber that will probably eventually replace our current SRT-4?
and...
What would you rather see, personally, a revised "Neon" or continuation of current SRT-4, or go with the new Caliber and start with a clean slate + all the knowledge you have from this version?
Thanks Again,
Eric
eric_t12 is offline
Old 12-07-2005, 10:32 PM   #52 (permalink)
Member Number: 16468
1) why is our turning radius so bad
2) how dangerous would a carbon fiber hood be in a crash?
Persicutor is offline
Old 12-07-2005, 10:43 PM   #53 (permalink)
Overcome's Avatar
Member Number: 24451
The whole powertrain in our cars takes up quite a bit of real estate and curse us with perpetual three point turns.
Very if the hood isn't designed properly. Just ask the guys at Carbon By Design.
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Overcome is offline
Old 12-08-2005, 11:17 AM   #54 (permalink)
dcsax's Avatar
Member Number: 4232
Trader Rating: (13)
2) how dangerous would a carbon fiber hood be in a crash?[/quote]
If its designed properly, it will have two notches in the underside that act as folding points. I rememeber going to the Hotchkis meet that Carbon By Design was at. They said that their street hoods have the notches and are tested to fold in a crash. I hood w/out these folding points (such as a race only hood) can be very dangerous. If the hood is not allowed to fold, it came come straight through the windshield and decapitate the driver. But like I said, CBD's carbon street hoods are safe and do fold.
Mods: Lots of stuff
dcsax is offline
Old 12-08-2005, 11:30 AM   #55 (permalink)
all_bran's Avatar
Member Number: 22506
2) Use some discretion... DCX SRT engineers won't be able to comment on this.
all_bran is offline
Old 12-08-2005, 11:32 AM   #56 (permalink)
all_bran's Avatar
Huh? The pedal servo is actually installed in our cars but not the controller?? What is installed in our cars if not within those dates? pedal servo?
all_bran is offline
Old 12-08-2005, 11:53 AM   #57 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Why is the turbo in the back of the engine bay? I hate it there...
Thats where the exhaust ports are. This isn't a Japanese car.
They covered this in the OLD SCHOOL live chat they did a few years ago. The response was "There was only so much room in the stable, and we decided to fill it with horses"
The vacuum actuator for the regular Neon sits right about where the turbo is on the SRT-4. Given how cramped our engine bay is, they elected to omit it.
what's the plastic blade under the front fascia for?
Air Dam (n)
A device made of metal or plastic fitted beneath the front bumper of an automobile and intended to enhance aerodynamics and stability by blocking the flow of turbulent air under the chassis.
Not sure of where it would go [brake fluid]... but if the light goes on during acceleration is washes to the back of the tank triggering the light.
As the brake pads wear, the fluid goes into the calipers as the pistons are extended further. When you replace your pads and compress the pistons, you will likely need to remove some of the fluid you have added.
Guys, some of these questions are old and can be resolved with the SEARCH button. PLEASE search before posting in this thread. This is an 'Ask the SRT Engineers' thread not 'Edumakate the noobs' thread.
James NWSRT-4
READ AND LEARN:
jaymzx is offline
Old 12-08-2005, 12:05 PM   #58 (permalink)
all_bran's Avatar
^^ X2
Anybody have any ideas on the 0W40 post of mine from the beginning?
Quote: Originally Posted by all_bran
Well, my question is regarding the recommended motor oil for the SRT4. I live in Royal Oak, MI (20 min south of DCTC in Auburn Hills). The manual recommends 5W30 year-round for our climate. What would be the pros/cons to using 0W40 oil? What are the considerations when using it (if any)? I usually allow 3 min of warm-up time. Mobil 1 recommends it for all turbocharged cars.
There is a european theory that this car was developed around 0W40 but most people in North America don't understand what a 'warm up' process is. They just slam the car into gear and mash the gas before it's even started! Thus, why most cars in NA have 5W30 or 10W30 recommended. (Crossfire uses 0W40, but is mfg'd in Europe)
BTW, 0W40 did get rid of my hard-starting issues.
I would jsut like the mfg'r to clear this up, because it's such a unique vehicle to the DCX product offering. THANKS!
all_bran is offline
Old 12-08-2005, 02:30 PM   #59 (permalink)
Punch's Avatar
Member Number: 3132
I don't beleive this answer, the pt cruiser turbo is a tighter fit, and we have cruise control!
2003 PT Cruiser GT HO, Stage 1, Prototype hardpipe's, maxfab 3" DP, Borla dual's, plastic intake, NGK 4306 @28.
Punch is offline
Old 12-08-2005, 02:56 PM   #60 (permalink)
jaymzx's Avatar
Member Number: 278
Trader Rating: (12)
Yes, but I'm sure the cruise control for the PT was a worthwhile engineering/cost feat, considering the demographic buying PT's. They get arthritis in their ankles and cruise could be a make or break deal for them . The 'go fast' crowd wouldn't be expected to complain as much.
jaymzx is offline
Closed Thread
Page generated in 0.22357 seconds with 13 queries
