Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT / Mopar / SRToc / Nationals Discussion > SRT Engineer Q/A Area
Closed Thread
Old 10-13-2008, 02:34 PM   #346 (permalink)
radicalmark29's Avatar
Member Number: 55274
Trader Rating: (20)
I would like some follow up on the third gear problems that have been recently discovered.
In reguards to this thread.
3rd gear grind, Factory defect found?!! *pics* Chrysler, ARE YOU LISTENING?
..then i want a new damn tranny because my 3rd gear is FUCKED!@
WTB: CF rear diffuser
radicalmark29 is offline
Old 10-13-2008, 02:40 PM   #347 (permalink)
Member Number: 1564
I would like the engineers to explain why the new Challenger is so heavy.
For example:
.........SE 2dr Coupe..........R/T 2dr Coupe..........SRT8 2dr Coupe
Curb........3,719 lbs..................4,041 lbs.....................4,140 lbs.
Those number seem awfully high for a 2-door coupe.
I would also like to know if they have any practical recommendations on what if anything can be done to reduce the weight.
Thanks.
Simon.Starkie is offline
Old 10-13-2008, 02:50 PM   #348 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
For example:
Thanks.
If you haven't seen it already, check out mopar's site as they have a 'drag pak' challenger that offers weight reduction to the sum of ~1000lbs...
I take it to be a stripped down car kinda like the comp coup.
a853rox is online now
Old 10-13-2008, 02:59 PM   #349 (permalink)
Member Number: 1564
Thanks.
Yes, I saw that at this link Mopar - Performance - Dodge Challenger Drag Race Package Car
It's what prompted my question.
The third bullet says :
Weight reduced by 1,000 pounds by removing major components and systems
That's a lot of weight.
I assume that does not mean the engine was removed
And the pictures at that link seem to show
1) a carb'd hi-rise (probably not street legal) so not sure how much weight saving is there
2) and 3) what appears to be a faily "full interior".
While a 3140 pound SRT-8 drag car would awesome, a 3600lb or 3700lb daily driver could be fun!
I don't listen to the radio much...
Old 10-13-2008, 10:08 PM   #350 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
Thanks.
Yeah, I know the ammenities such as AC and radio are gone, I would suspect that the sound deadening and spare tire are gone as well. On the site they did say the windows were lexan too... I wonder if any CF or fiberglass is involved too..
Old 10-16-2008, 01:02 PM   #351 (permalink)
Member Number: 1564
They said this about that:
Team SRT
SRT Engineering Team
The weight loss comes from component removal, a modified BIW and several lightweight components. The BIW is based off the production Challenger - no door beams, no body sealer, etc. Components removed include the power steering system and HVAC. No component weights are available off-hand. Lightweight components are polycarbonate door glass, carbon fiber liftoff hood, performance front brakes, Viper-style front seats.
What is BIW? From Body in White: - encyclopedia article about Body in White:.
Body in White
0.04 sec.
Body in White or BIW refers to the stage in automotive design or automobile manufacturing in which the car body sheet metal (including doors, hoods, and deck lids) has been assembled or designed but before the components (chassis, motor) and trim (windshields, seats, upholstery, electronics, etc.) have been added.
The name is derived from manufacturing practice before steel monocoque bodies, sometimes trademarked unibody. When most cars were made by firms as just a frame, with an engine, suspension, and fenders attached, the manufacturers built or purchased wooden bodies (with thin, non-structural metal sheets on the outside) to bolt onto the frame. The bodies really were painted white as a preliminary to being painted the customer's chosen color. During the Great Depression, firms had a large inventory of these bodies and took a long time to sell them off. Now that car bodies are made of steel, the phrase remains and has a folk etymology that it comes from the appearance of the car body after it is dipped into a white bath of primer (undercoat paint)—when actually the color is usually light gray.
In car design, the Body in White phase refers to the phase in which the final contours of the car body are worked out, in preparation for ordering of the expensive production stamping die. Extensive computer simulations of crash worthiness, manufacturability, and automotive aerodynamics are required before a clay model from the design studio can be converted into a Body in White ready for production.
Automotive design is the profession involved in the development of motor vehicles or more specifically road vehicles. This most commonly refers to automobiles but also refers to motorcycles, trucks, buses, coaches, and vans.
..... Click the link for more information.
Monocoque (French for "single" (mono) and "shell" (coque)) is a construction technique that supports structural load using an object's external skin. This stands in contrast with using an internal framework (or truss) that is then covered with a non-load-bearing skin.
Editing of this page by unregistered or newly registered users is currently disabled due to vandalism.
If you are prevented from editing this page, and you wish to make a change, please discuss changes on the talk page, request unprotection, log in, or .
Folk etymology is a term used in two distinct ways:
* A commonly held misunderstanding of the origin of a particular word, a false etymology.
* "The popular perversion of the form of words in order to render it apparently significant"[1]
A primer is a preparatory coating put on materials before painting. Priming ensures better adhesion of paint to the surface, increases paint durability, and provides additional protection for the material being painted.
For other uses of this term, see Die.
A die is a specialized tool used in manufacturing industries to cut, shape and form a wide variety of products and components.
crash test is a form of destructive testing usually performed in order to ensure safe design standards in crash compatibility for automobiles or related components.
Types
* Frontal-Impact Tests
Automotive aerodynamics is the study of the aerodynamics of road vehicles. The main concerns of automotive aerodynamics are reducing drag, reducing wind noise, mimimising noise emission and preventing undesired lift forces at high speeds.
This article is copied from an article on Wikipedia® - the free encyclopedia created and edited by online user community. The text was not checked or edited by anyone on our staff. Although the vast majority of the Wikipedia® encyclopedia articles provide accurate and timely information please do not assume the accuracy of any particular article. This article is distributed under the terms of GNU Free Documentation License.
Old 10-25-2008, 01:08 PM   #352 (permalink)
Member Number: 65912
Hello friends¡
My question is about air/fuel ratios.
Recently had the chance to buy a 2005 SRT-4, what is already equipped with a stage 3 kit, including computer, a big front air-to-air intercooler, supposedly good to 550 HP, an AEM a/f ratio and an Apexi fuel conrtroller which is connected but not operating.
So, I live in a very high altitude place named Mexico city. Here we are located at 7460 feet altitude; airplane cruising altitudes.
Now the thing is that when running the car wide open throttle I have ten to one a/f readings. I´ve been said this is the stage 3 computer calibration.
But daring to use the Apexi, I suppose I can run much leaner to obtain a better torque curve. How much leaner would be reasonable to run this combo, yet safely for street and road racing usage?
One more comment in favor of Chrysler engineering. It happens that these cars are the fastest of all other brands of full body, front wheel drive cars on our racetracks.
A thousand thanks.
lordvader is offline
Old 10-26-2008, 02:24 AM   #353 (permalink)
A thousand thanks. I will be aware for the next engineers session.
Old 10-28-2008, 12:14 PM   #354 (permalink)
Adrian_RT's Avatar
Member Number: 28781
Man...don't worry, in Mexico city the cars always run very rich with out safc,mapclamp or return line.
Even a 20g or gt3076 and 750rc run pretty rich.
Go to Cuernavaca-Acapulco and you see 10.5 even 10.8 on dab 3.
Worry about your disease...hahahah
Adrian_RT is offline
Old 10-30-2008, 07:28 PM   #355 (permalink)
Member Number: 68671
My question would be, I just bought an 05' Srt-4 ACR St 2 and have an oil leak. From what I read there notorious for this which from how it looks is this. Car will leak oil.from the manifold into the intercooler pipe connected through the throttle body. What do you do??? Also, oil catch can would help I imagine??
05ACRSTG2 is offline
Old 10-30-2008, 08:12 PM   #356 (permalink)
gottasrt4's Avatar
Member Number: 57792
Trader Rating: (10)
LoL
LoL, uhhh yea....that's what the catch can does, bud.
gottasrt4 is offline
Old 01-06-2009, 06:23 PM   #357 (permalink)
moparx12's Avatar
Member Number: 51815
why does the speedo bounce on many peoples' cars when cruising?
moparx12 is offline
Old 01-06-2009, 07:53 PM   #358 (permalink)
gottasrt4's Avatar
Trader Rating: (10)
Question bouncing
.......with your foot not moving???
Old 01-06-2009, 09:29 PM   #359 (permalink)
moparx12's Avatar
^^^ foot not moving and speed not changing.
moparx12 is offline
Old 01-07-2009, 06:13 AM   #360 (permalink)
gottasrt4's Avatar
Trader Rating: (10)
yeaa
yeaaa, mine'll do that at WOT sometimes, but if it's doin' that on the regular, it sounds like a boost leak.
Closed Thread
Page generated in 0.25692 seconds with 13 queries
