i was thinking since i wouldnt want to be connecting n disconnecting the laptop, maybe if we hold the button longer it can be used for setting up the 2step?
one question, what happens if we r using the 2-step - rev-limiting to launch on boost but then we have our water/alch. injection setup to spraying???
Use an Aquamist hfs-5, where it sprays based on your fuel injector pulse-width.
That is a possibility. I'll think about it. You could hold the button for like 30 seconds until the end of the cut time options, then it would go into some kind of new flashing pattern. At that point you could rev the car to the RPM you want it to hold and then hit the button once. That might work....
Hmm... I don't know about this. My guess is that you'd want to set your W/I setup to come on at a higher boost / speed level.
Well, you'll definitely need a laptop to do the software upgrade. We'll see if we can come up with a way to set the 2-step level without a laptop. (if we can get the 2-step to work!)
guess upgrading mine will be easy... still haven't had time to put the damn thing in. :cry:
. . . . the Kid . . . . . . . . . . . the Car . . . . . . . . . . . the Bike . . . . . . . . . . the Toy . . . . . .
And my real name is George Carlin.
