I don't have a wiring diagram yet, but I do have pictures from my install. This is how I did it. It is pretty easy. I recommend the fuel cut because it should be easier on your turbo and your cat. However, you can run the 2-step without this. You just wire the ignition only cut.
like the NDE 2 step no? hence the ridiculous shotgun effect?
Yeah, I think you'll have a ridiculous amount of popping and banging without fuel cut. Even with the fuel cut it starts popping above 4200 RPM.... So, that's why I recommend the fuel cut.
Well, I just finished testing the first complete WOT Box and 2-step load. Everything *appears* to work, so I've sent it over to Jay to try on his car... And now I will sit back, crack open a beer and make some lasagna.
Umm so we will have 2 choices, nice.
Even tho its not best for the turbo (I dont have a cat so..) I think I'll still go with only ignition cut. Popping, flames, etc. is awesome. Anyway I'll be only doing it on a track so ... :P
Ok. I'm not entirely sure if it work with the ignition only cut. It might not hold the RPM well enough. But, you can test it if you want and let me know if it works. It might overshoot and not be able to hold the RPM you want... I guess we'll find out!
I can try it out as soon as my car gets out of the shop in 2 maybe 3 weeks if you still didnt find out if it works with only ignition cut.
If you test it before please let us know Im sure there are others willing to know.
seems pretty simple to me. Just adding the one wire or do we have to switch pins around?
oh and of course the injector wiring.
You have to move the clutch switch from the yellow wire to the green wire. You may need to add the green wire, if you don't have it. For a while we stopped shipping WOT Boxes with the green wire because we thought we were never going to use it.... So, if that is the case, let us know and we'll ship you a pin and green wire.
You will also need to extend the yellow wire to reach into the engine compartment and connect to the cam position sensor. Use Yellow 18 AWG wire, preferably automotive grade wire.
And you will need to wire in the fuel injectors with some 16 AWG wire. You might need to go get some more of that if you threw out the left over piece from the original install.
The new kits will ship with enough wire for these connections. Our apologies to the older WOT Box owners if you don't have enough wire. We didn't expect to be able to do this!
This product sounds just exactly what I need. If you need a volunteer beta tester, just let me know. I already have your code scrubber and Toybox 2.0 and am already planning on getting a WOT Box. I hit the strip about once a month but have back country roads just a few miles from my house that I do a little testing on.
Mario Kovach, Administrator: Probetalk.com
2005 S3R Stone White Srt-4
USAF Explosive Ordnance Disposal Craftsman
Wiring looks easy enough. What if i lost my serial cable, how much for a new one? Think i will need the one wire you talked about too. My unit is still pretty new so i think it is the one with out it. Any idea when release dates will be yet? I am subscribed to both threads
Yes. Free upgrade. We'll post it to our website once we have completed beta testing.
Take a look at your WOT Box and check if it has any green wire at all or if it has an open hole in the connector there. If you have a short piece of green wire, you can just extend it. If you have no green wire at all, we'll have to send you a pin and wire.
