Old 08-15-2008, 08:42 PM   #211 (permalink)
rollwitstyle's Avatar
Member Number: 60104
Trader Rating: (20)
installed my wot box and 2 step today, works great but i keep getting a p0300 code, i have the 2 step set to about 3000-3200 rpms. is this normal? is there a way to get rid of it? thanks.
NY SRT CREW
rollwitstyle is offline   Reply With Quote
Old 08-15-2008, 10:28 PM   #212 (permalink)
Gslocum's Avatar
Member Number: 50480
Trader Rating: (13)
Default Need Help!
for some reason, the WOT BOX isn't recognizing the clutch upstop switch on my '05. The green wire from the WOT BOX is soldered properly into the correct green/black wire, but when I test it, it won't work... the clutch upstop switch is plugged in correctly, the car starts so the switch is good - i did two cars at the same time and one worked flawlessly and the other won't. what gives?
Gslocum is offline   Reply With Quote
Old 08-15-2008, 10:45 PM   #213 (permalink)
Gslocum's Avatar
Trader Rating: (13)
just finished resoldering the green wire to the upstop switch under the dash and there was no change.
Old 08-15-2008, 11:00 PM   #214 (permalink)
Novak94's Avatar
Member Number: 45523
mines 05 and i have no problems at all, maybe check the green wire on the wot box to make sure its not internally broke anywhere
Old 08-15-2008, 11:55 PM   #215 (permalink)
Gslocum's Avatar
Trader Rating: (13)
wire is straight no kinks, no breaks....
Old 08-16-2008, 12:22 AM   #216 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by SRT-4_ACR View Post
like?
Well, it is still a misfire, so you have unbalanced harmonics plus more wear on the turbo... I don't know exactly, but don't do it for like minutes at a time. I wouldn't recommend that! Use it as a tool to launch the car, not as something to make noise...
Old 08-16-2008, 12:24 AM   #217 (permalink)
Trader Rating: (95)
Is it a 2-step only box? you may need to upgrade to the latest software. the previous versions didn't do the LED test with the clutch switch.
N2MB Racing - SRT-4 WOT Box Software
After that, get out the volt meter and check the voltage at the connection. Perhaps the switch is broken? You'll need to check it there.
Old 08-16-2008, 12:27 AM   #218 (permalink)
Trader Rating: (95)
The multiple misfire is unavoidable with the stock ECU and any 2-step. Luckily, it does not impact performance in any way.
Upgrading to a staged PCM should get rid of it, or you can always run your car with less than 1/4 tank of gas. Oddly, that will prevent the CEL as well...
Old 08-16-2008, 12:31 AM   #219 (permalink)
Gslocum's Avatar
Trader Rating: (13)
This is a 2step + WOT box. Where would I check the voltage at the connection with a volt meter? Thanks, we are still up trying to figure this out before giving up for the night!
Old 08-16-2008, 12:35 AM   #220 (permalink)
Trader Rating: (95)
Check it at the splice you made at the green / black wire. With the key on, but car not running you should show 0 volts with the clutch up, 12 v with the clutch down.
Old 08-16-2008, 01:03 AM   #221 (permalink)
Member Number: 37603
Trader Rating: (26)
ROFFLE exactly!
F/S:
MPx 3"axleback(Duals &small piece,no midsection or DP)
Stage 1 Injectors
Stock Mani
Stage 3 o2
SRT-4_ACR is offline   Reply With Quote
Old 08-16-2008, 01:09 AM   #222 (permalink)
Gslocum's Avatar
Trader Rating: (13)
Checked the splice connection with a multimeter and Im showing no change with the clutch in or out..BUT the car will start!! Why would the car start if the switch wasnt working - if you get this, Phrozen, try and call me - Gabe 702.308.1922! Im still up..
Old 08-16-2008, 03:02 AM   #223 (permalink)
sideshosk8's Avatar
Member Number: 48387
i thought it was a bright green wire, not green/black wire.
I just installed mine on my 05 and it works flawlessly! all I can say is wow... just wow! n2mb you guys rule!
sideshosk8 is offline   Reply With Quote
Old 08-16-2008, 03:18 AM   #224 (permalink)
Gslocum's Avatar
Trader Rating: (13)
Looks like green and black to me?
Old 08-16-2008, 03:39 AM   #225 (permalink)
sideshosk8's Avatar
so it reads 0 while its up and all the way down?
I thought it was just bright green, but I was crammed in there with a flashlight between my neck and shoulder, and could hardly move my arms. my bad man,guess im not much help lol.
Page generated in 1.10705 seconds with 13 queries
