Old 08-13-2008, 06:40 PM   #181 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by Bomb Squad View Post
Out of curiousity, how many of the 250 units have sold so far?
About 150 of the 250
I already ordered another 250....
Old 08-13-2008, 08:35 PM   #182 (permalink)
01StratRT's Avatar
Member Number: 3294
Not sure if this has been mentioned yet or not but the 2 Step RPM Chart that shipped with my WOT box is 3000 RPM - 7400 RPM. The 2 Step RPM Chart posted on your website is 2000 RPM - 6400 RPM and it appears to be correct with my WOT box.
Mods:
ED Super Beast IC
PTP Check Valve
Mopar STS
Gerry's Custom door sills & shift knob
Realtune 60mm TB
JMB SRI & CC
AGP Trans & Motor mounts
DCR Oil modifier
01StratRT is offline   Reply With Quote
Old 08-13-2008, 09:55 PM   #183 (permalink)
Trader Rating: (95)
That is correct. Sorry, I need to update the printed directions. However, I may change it back. 2-stepping below 3000 RPM is not recommended because it sets fuel injector codes and triggers the limp mode.
I've left it there because if you really need to 2-step below 3000 RPM, you can modify your installation to ignition only... but.... I don't think that's a great trade-off.
Old 08-13-2008, 10:06 PM   #184 (permalink)
Matts04SRT's Avatar
Member Number: 58076
DO you still have the WOT boxes for sale?
Matts04SRT is offline   Reply With Quote
Old 08-13-2008, 10:07 PM   #185 (permalink)
Trader Rating: (95)
Yes. You can order from this thread or on our website at NP Complete Performance
But, hurry... The VW and Audi guys are buying them up like crazy... :-)
Old 08-13-2008, 10:19 PM   #186 (permalink)
Matts04SRT's Avatar
money sent: Receipt ID: 9PA40232D2408022P
Thanks
Old 08-14-2008, 12:20 AM   #187 (permalink)
Novak94's Avatar
Member Number: 45523
haha after i tried the 2-step at like 2400 rpms i figured the engine would die if i popped the clutch. Sounds kinda cool that low though, but u get the FI codes and will have to reset your pcm.
Old 08-14-2008, 11:18 AM   #188 (permalink)
01StratRT's Avatar
Member Number: 3294
Question
I set it to 3 blinks thinking it was 3400 RPMs and it turned out to be 2400 RPMs. The MIL was blinking for about 30 seconds or so before it went out. As far as I can tell performance is unaffected. What happens when it goes into limp mode? is there a display code? and what needs to be done to correct it if it is in limp mode? Thanks
Old 08-14-2008, 11:19 AM   #189 (permalink)
Trader Rating: (95)
Mine would start popping when I tried to free rev it past 4800 RPMs with that code set. Once I cleared the code, the problem went away. It is a rather strange fault code...
You can pull the battery to clear it or pop that fuse out...
Old 08-14-2008, 12:46 PM   #190 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
below 3k if you set codes for insufficient ionization and go into an ignition limp in mode.you wont be able to rev over 4800 rpm.the pcm doesnt know what is happening with ignition so it will limit it to prevent knocking
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 08-14-2008, 01:20 PM   #191 (permalink)
gq4life's Avatar
Member Number: 10297
where's the vids of 2 stepping & shooting flames?
also y is it bad to not cut fuel? u wash cyclinder walls after awhile?
Old 08-14-2008, 01:21 PM   #192 (permalink)
01StratRT's Avatar
Member Number: 3294
Thumbs up
Ok cool I didnt go into limp mode. Other than figuring out the 2 Step chart everything is working great! Awesome product. Any idea on when we might see the gui for it? Thanks
Old 08-14-2008, 01:23 PM   #193 (permalink)
Trader Rating: (95)
If you do ignition only, it is more likely to damage the catalytic converter since there will be more unburnt fuel igniting there...
Old 08-14-2008, 01:30 PM   #194 (permalink)
Redlined16's Avatar
Member Number: 47276
cats are only good as pets. they dont belong on a car.
it's just a neon with exhaust
Redlined16 is offline   Reply With Quote
Old 08-14-2008, 02:43 PM   #195 (permalink)
Trader Rating: (59)
quoted for truth!!!
Page generated in 0.21135 seconds with 13 queries
