Same here, Best Buy and Circuit City were both soldout. I had to go to staples and spend almost 40$ for some fancy ass one from Belkin I think......oh well, I have one and thats all that matters haha.
I need a green wire and a pin. I pm'd you both but was just curious if you got it? Shall I email? Can't wait to get this set-up, and my next time at the track should be a little more interesting......;-]
great work again guys. I already have it d'led and have the time to wire the changes, but I just need to find somewhere around me that stocks the DB9 to USB
Try radio shack, circuit city, best buy, fry's, etc.... Online is probably your best bet, though. It'll be cheaper and delivered to your door in 2-3 days....
i work at a BB and no dice, cc, radioshack are no go's as well but I found a regular db9 cable at staples for $10. thankfully the laptop in my shop here at work is ancient and has a serial port.
on to install.
just want to verify, pin 1 should be yellow to CPS, pin 5 should be green to clutch upstop correct? I don't have a green wire so I'll be soldering leads to the board.
on to install.
agh. don't do that.. let us send you a pin and wire. It'll be hard to remove your WOT Box from your car if you need to, plus we won't be able to warranty your WOT Box if you solder to it....
i'm cool with it. I solder every single day at work all day long, I trust in my abilities. I soldered leads on for an external LED to go along with my toys ones like 6 mos ago so its too late anyway.
DISCLAIMER: nobody else do this
finally got around to changing mine. All together it took around 45 mins (i'm really anal about working on my car) and was SUPER easy. Very well thought out and put together. Software was way easier than I thought and works GREAT. A+ again guys!
