Old 11-17-2007, 06:42 PM   #1 (permalink)
Member Number: 41965
Default Toybox 2.0 install
Installed the New and improved Toybox 2.0 today.
The hardest part was finding my soldering gun with the inside to outside wire harness route being a close second.
I mounted the unit on the left side of the dash next to the defroster vent for the side window. I used the 3/32 drill to drill a little hole then found 2 little screws to mount the unit. You can route the harness along the dash and thru the fuse box.
I used about a foot long tie wrap to fish the wire up to the outer body hole then went thru the top of the fender and down the left side underhood to the PCM. It was a line of vision thing so I never took off the wipers or any of that stuff.
Another problem was taking off the plastic covers on the connectors! What a pain in the ass. Chryslers fault not yours. Had a real problem trying to release all 4 of the locking tabs at the same time.
Finding the correct wires and soldering was no problem.
I was a little nervious about finding the correct cavitys for the terminal install but basically if you can count to 22 you've got it. The instructions looked worse than what it is. After I drilled out the back of the connector for the terminals I used the next smaller sized drill to push out the stem fillers.
CONCERN: I was a little concerned because none of the terminals really locked into place are they supposed to? After taping and reinstalling the black plastic covers they didn't appear to move much.
I got done about 8 o'clock tonight and it's raining and really shitty outside so I decieded to set the peramiters tomorrow. Can't test in the rain anyway!
2ND CONCERN: When I turned the ignition on the readout on the unit was really bright! I'm hoping when I program it tomorrow the dimmest setting on the indicator will work better for me cause I do a lot of my driving at night.
Overall the install wasn't bad at all. Lots of little cuts on my hands but that's the price you pay for having so much fun!
MOPARJON
Jon Zapf is offline   Reply With Quote
Old 11-18-2007, 09:44 AM   #2 (permalink)
Member Number: 25854
Trader Rating: (95)
Great install review!
1st concern: You can know that the pins are seated if you look at the connectors from the pin side and make sure the one you added is as close to the front as the other pins that are already there.
2nd concern: I think when the Toybox 2.0 starts up, it is on full brightness for 5 seconds. Also, when you push buttons it goes to full brightness for 5 seconds. After that it dims down to your dim setting. The default is fairly bright. It's a setting I found I could read in all light levels. But, there are a bunch of other dimmer settings that get much dimmer.
Let me know what you think once you try it out!
Thanks!
Old 11-26-2007, 05:18 PM   #3 (permalink)
Default My Fault
After I installed the unit I had a problem with HOM mode. Long story short it was self inflicted.
The C14 terminal wire wasn't pushed far enough into the hole. No contact = no voltage = no voltage = no HOM.
Make sure your terminals are even with the other contacts in the plug!!! It says that in the instructions but of coarse I didn't pay attention. I had to make the holes in the back of the plug a little bigger with a 1/16 drill bit. I just took the corners off the 3/32nd hole you drill then pushed the terminals in with the back of the 1/16 drill bit.
Phrozen is a hell of a guy he talked me thru everything I had to do to problem solve the unit! He went abouve and beyound the call of duty on this one. Thank you, Thank you, Thank you!!!!
Everything works like it should and I can't wait for dry roads for a real test.
Old 11-27-2007, 06:46 AM   #4 (permalink)
Trader Rating: (95)
Glad to hear you found the problem. I was about to give up and have you send it back. :-)
Enjoy the Toybox and thanks for helping to spread the word with your review!
Page generated in 0.14923 seconds with 13 queries
