Old 07-26-2007, 03:47 PM   #361 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (39)
Quote: Originally Posted by phrozen
Quote: Originally Posted by Philth
Phrozen - Just to confirm.....
The WOT shift box needs to be installed closest to the ignition coil, with the New Design Elec. TCS box installed farthest away from the ignition coil?
BTW...I hope I get this by Saturday...it's my only free day
Take a look at our installation diagram:
http://npcomplete.pbwiki.com/WOT-Box...n-Instructions
You want the TCS box to get it's power from the RED side of the 16 AWG pair. The black side is going to get cut off during WOT shifts, which would be bad for the TCS controller.
Sorry I am already in bed getting ready to go to sleep for a nice 5am wake up for Squadron PT. OH BOY!!!!!!!!
so anyway, what wire does the TCS run off of? I will have to take a look tomorrow to refresh my memory but I just wanted to know in advance if it was already setup on the black wire so that I would have to switch it.
scottw03 is online now   Reply With Quote
Old 07-26-2007, 05:02 PM   #362 (permalink)
Member Number: 25854
Trader Rating: (95)
The TCS does its work on the low sides of the coil, pins 1 and 3. However, it powers itself from the high side of the coil, pin 2. We don't touch the low side of the coil, but we do cut off the high side. We don't want to kill power to the TCS, so make sure the TCS power tap is done before (farther from the coil) the WOT Box splice.
I need to draw this up for future reference.
Old 07-26-2007, 05:16 PM   #363 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
Member Number: 39843
Trader Rating: (167)
could you guys possibly provide a detailed pic or explanation of exactly what wire to use for the tps? i know that when you do the tps rewire you end up with 2 solid orange wires & 1 blue wire .... according to the install instructions we need to tap into the orange/dark blue wire but i dont know which one that is w/o seeing a pic
Old 07-26-2007, 05:18 PM   #364 (permalink)
1badsrt-4's Avatar
Member Number: 21276
Trader Rating: (53)
Nate do you have yours yet. We should install them together, that way it only takes us 10 hours
11.34 @ 128.33 mph. Stock motor, head, cams and ecu
1badsrt-4 is offline   Reply With Quote
Old 07-26-2007, 05:22 PM   #365 (permalink)
Senior Moderator
SRT of the Month
uncommon©'s Avatar
lulz ... no i didn't get mine yet
jay sent me a pm tuesday saying it'd be going out any day now ... my guess is i'll probably get mine the same day you get yours
Old 07-26-2007, 05:25 PM   #366 (permalink)
Trader Rating: (95)
I highlighted the signal wire on the connector pinout diagram:
http://npcomplete.pbwiki.com/f/srt-t...sor-pinout.GIF
It's the middle wire in the connector.
Old 07-26-2007, 05:26 PM   #367 (permalink)
Trader Rating: (95)
Yours went out today. The rest should go out tomorrow.
Old 07-26-2007, 05:27 PM   #368 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Is that the same wire that we run the Tach adapter to for the SAFC's?
Old 07-26-2007, 05:27 PM   #369 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Jay Pmed me earlier to tell me. But thanks meng
Old 07-26-2007, 05:29 PM   #370 (permalink)
Trader Rating: (95)
I don't know. It should be hard to get wrong, since it's a 3 pin connector and we want the middle wire. no matter how you look it, you'll get it right... :-)
Old 07-26-2007, 05:30 PM   #371 (permalink)
Trader Rating: (95)
Also, as the instructions state, you guys can probably leave out the MAP sensor wire for now. It's not implemented in the firmware anyway, and I suspect most people won't need it.
However, don't cut off the wire or otherwise damage it. You may want to use it later, once I implement it in software....
Old 07-26-2007, 07:46 PM   #372 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Got ya.
Quick question, would it be feasible to actually tap the red wire in the WOT harness for power to the TCS box? I want to hack the stock harness as little as possible...
Also, what's this "optional" connection for the MAP sensor do for us?
Old 07-26-2007, 08:12 PM   #373 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
Got ya.
no that is the asd feed into the wot box,we dont want any thing else on that wire.its noisy enough
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 07-27-2007, 12:18 PM   #374 (permalink)
1badsrt-4's Avatar
Trader Rating: (53)
Just got mine today.......Thanks a bunch N2MB you guys friggin rock. I will be installing it this weekend and I will let everyone know how it works
Old 07-27-2007, 12:24 PM   #375 (permalink)
scottw03's Avatar
Trader Rating: (39)
Nothing for me I guess I will have to try to WOT shift the old fashion way.
Page generated in 1.13048 seconds with 13 queries
