Old 05-25-2007, 01:38 PM   #16 (permalink)
carlosraf20's Avatar
Member Number: 39864
Trader Rating: (20)
Quote: Originally Posted by never2muchboost
Quote: Originally Posted by carlosraf20
will these work on a car that has a MSD DIS-2 ignition ?
and yeah 2 vesions should be out one with the data log , and one with out.
I'd need to check their schematic, but most likely it should work great.
We'll think about the 2 versions.
cool is you can let me know if it works with the MSD DIS-2 ignition I will buy it
yes sir! it will work on any ignition set up
thats all I need it to know
carlosraf20 is offline   Reply With Quote
Old 05-25-2007, 01:45 PM   #17 (permalink)
distinctdev's Avatar
Member Number: 22976
Trader Rating: (32)
last time i checked the srt has a clutch switch....
R.I.P. Steven Lorenz 04.04.06
MySlips.com
Bench Racing Stops Here.
distinctdev is offline   Reply With Quote
Old 05-25-2007, 01:47 PM   #18 (permalink)
Member Number: 25854
Trader Rating: (95)
The factory clutch switch is only activated at the bottom of the pedal travel. That would make the signal too late to be useful. We add a switch that gets triggered as soon as you barely touch the clutch at all, so the trigger happens very quickly.
Old 05-25-2007, 01:50 PM   #19 (permalink)
Trader Rating: (95)
Good questions... I'm updating the FAQ on the webpage.
Old 05-25-2007, 01:56 PM   #20 (permalink)
Pinebox's Avatar
Member Number: 7440
Nice!!!!
Little pricier that I was expecting. But, then again, I looked at the price first and was But, then I read everything it does. Then the price didn't seem bad at all.
+1 for a "lite" version with no data logging.
Either way, I'm saving pennies for this thing.
Pinebox is offline   Reply With Quote
Old 05-25-2007, 01:58 PM   #21 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (431)
Our version works -P-, so Im assuming yours should also?
www.Realtuned.com
Each car built/tuned/track prepped in house
{9.98@144 Squishy332000 build}{10.08@148 Erabbit23 build}{10.43@139 Fred@Realtune build}{10.62@138 Karkraft build}{10.88@129 90VNT build}{10.97@136 srt4me18 build}{10.99@135 Mezturbo4 build}
{11.62@128 Realtune Caliber}{11.85@119 Whoosh@Realtune Caliber}
Home of the Worlds Quickest/Fastest CSRT-4, Manual NSRT4, and Stock turbo SRT4
Old 05-25-2007, 01:59 PM   #22 (permalink)
Member Number: 623
BTW, for people beatching about the price.......You have no idea what your missing.
Old 05-25-2007, 01:59 PM   #23 (permalink)
Trader Rating: (95)
Well, then ours should too. I just haven't seen the schematic for the MSD ignition, so I didn't want to comment on it blindly.
Old 05-25-2007, 02:01 PM   #24 (permalink)
Trader Rating: (32)
so wait will this work on my z06?
Old 05-25-2007, 02:03 PM   #25 (permalink)
Trader Rating: (95)
Do you have a common positive lead ignition setup and a 5V TPS sensor? If so, then YES!
You will need to come up with your own mounting bracket for the clutch switch, but it shouldn't be too hard.
Old 05-25-2007, 02:06 PM   #26 (permalink)
Member Number: 623
Thats the only tricky part. It needs to be set up also so it doesnt kick back and double cut. It took us a few times before we got that figured out.
Old 05-25-2007, 02:08 PM   #27 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
we made software that locks that out.it can only actuate once until the circuit rests for one second to prevent that kickback actuation.after one second its active again
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 05-25-2007, 02:09 PM   #28 (permalink)
Trader Rating: (59)
sure will..the only thing you will need to do is set up the included clutch switch on your pedal so that it signals at the top of clutch travel
Old 05-25-2007, 02:10 PM   #29 (permalink)
j2talc's Avatar
Member Number: 10319
Trader Rating: (36)
very nice. I'm in once I start tracking my car more
j2talc is offline   Reply With Quote
Old 05-25-2007, 02:13 PM   #30 (permalink)
Trader Rating: (32)
i beleive the car has a clutch switch like the evo since it has cruise control which needs to turn off if you tap the clutch
Page generated in 0.19973 seconds with 13 queries
