Old 06-12-2007, 08:21 AM   #151 (permalink)
Sota's Avatar
Member Number: 31159
Quote: Originally Posted by never2muchboost
Quote: Originally Posted by Sota227990
any thought given to how to put the box closer to the ECU? I'm all for the primary wires being as short as possible.
we designed it to be inside the car for ease of operation as well as the the elements.the less wires going through the engine bay the cleaner it will look anyway.im guessing your concern is rfi? it wont make a difference as long as your connections are solid
RFI, resistance losses, wire capacitance, signal waveform distortion, all those goodies. Keep in mind I'm planning on adding that TCS box as well, so the wiring chain gets even longer. Maybe I'm just paranoid as I think I've tracked my stumble down to the MSD tach adapter I installed last year; stumble coincides with the shift light not working.
Also, no USB port in place of the serial?
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 06-12-2007, 08:25 AM   #152 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
no problems with rfi or resistance, we originally had some issues with the clutch signal because of noise from the bus and the asd circuit but we fixed that.you can always get a serial to usb adapter,i prefer serial anyway because you dont have to worry about having to search the internet high and low for a driver
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 06-12-2007, 08:35 AM   #153 (permalink)
Sota's Avatar
I guess I can understand the USB driver issue deal. you guys supplying a serial interface cable as well?
Glad you got the clutch switch thing sorted out.
Old 06-12-2007, 08:48 AM   #154 (permalink)
Member Number: 25854
Trader Rating: (95)
The WOT Box uses an extremely low resistance solid-state switch and 16-awg wire to minimize the resistive losses. The wiring should not add any significant capacitance or inductance that would cause any real distortion in the driving signals. The RFI added is not significant since we are on the non-switched side. There is only the chance for RFI when we interrupt the ignition for the WOT shift, however we have taken steps to minimize the amount of energy that is radiated.
If you think about it, an after-market tachometer has a much higher likelihood of causing interference than the WOT Box. The tachometer will tap into the switched side of the ignition coil, so the wire that runs from the ignition to the tach will act like an antenna, radiating the ignition pulses all over the car. Since the WOT Box is on the non-switched side, the voltages in our wires remain constant, thereby causing no RFI.
Our test units have been on daily-driven cars for several months now and no problems have been observed. We'll keep a close watch on this issue.
The combination of the WOT Box and the TCS should not add any more resistance to the ignition circuit path, since the TCS should be actively regenerating the ignition drive signals.
Old 06-12-2007, 08:50 AM   #155 (permalink)
Trader Rating: (95)
We'll sell as an option a USB-to-serial adapter for those who have laptops that don't have serial ports anymore. I use just such an adapter all the time for my development because my laptop doesn't have serial ports. They work great for this kind of application.
Old 06-12-2007, 01:17 PM   #156 (permalink)
camlifter's Avatar
Member Number: 3008
Trader Rating: (25)
are they shiping yet, how about a low cost option that has no pc interface.
This post is completely ENVIRONMENTALLY GREEN. It was prepared using 100% recycled words and recovered hot air and other gases from the exhaust of the private jet Al Gore used to fly over to Norway and pick up his Nobel Prize. It has been further environmentally corrected and enhanced through the use of Intelligence Offset Coupons.
camlifter is offline   Reply With Quote
Old 06-12-2007, 02:02 PM   #157 (permalink)
Trader Rating: (95)
No, we're still waiting on the machine assembled boards. The board production and assembly takes a long time plus the parts are coming from the Philippines.
Since there are very significant tooling and NRE charges, we are not going to be able to make two different hardware versions. So, the PC interface hardware is going to be there no matter what. We may think about making a version with the interface disabled in software, but it would be kind of difficult. We'd have to maintain different sets of programmed units, and offer an upgrade path for people who buy it without the interface enabled and eventually want to enable it.
All of that adds complexity, so we felt it would be easier to just include it with all the units, just in case you want to use it later.
Old 06-13-2007, 02:48 AM   #158 (permalink)
Overcome's Avatar
Member Number: 24451
"It's the WOT box."
"The what? What box???"
"No WOT. It's called the WOT box."
"WHAT!?"
"NO WOT. FAWKING WOT BOX GAD DAMMIT!!!"
"WOT THE FAWK ARE YOU TALKING ABOUT!!??!!!111!!"
“Believe in yourself. Believe in your own potential for greatness. Believe that you can change the world. It is something that is within each of us.”
– Evan Michael Tanner 1971-2008
Old 06-13-2007, 07:13 PM   #159 (permalink)
Member Number: 24966
so are you guys gonna post a list of people who paid and when they ship out
srt-4toys is offline   Reply With Quote
Old 06-13-2007, 07:14 PM   #160 (permalink)
Trader Rating: (95)
We will contact each person individually when their orders ship.
Old 06-15-2007, 06:11 PM   #161 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (39)
Any projected date on these being ready? Just wondering on when I should check back to make a purchase.
scottw03 is offline   Reply With Quote
Old 06-15-2007, 08:33 PM   #162 (permalink)
Trader Rating: (95)
We're hoping to be shipping by the end of the month....
Old 06-15-2007, 08:36 PM   #163 (permalink)
Trader Rating: (95)
If anyone would like notice when the units are in stock and ready to ship, email us at autotrans@gmail.com to be put on the notification list.
Old 06-15-2007, 09:07 PM   #164 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
My wife would have my nuts......I need to refresh my mod buffer
OTownSRT4 is offline   Reply With Quote
Old 06-15-2007, 09:13 PM   #165 (permalink)
Trader Rating: (95)
You have to explain it like this... It's going to SAVE you lots of money on a new transmission!
Page generated in 0.22295 seconds with 13 queries
