Old 06-01-2009, 10:45 PM   #61 (permalink)
treydoggnrhs's Avatar
Member Number: 45468
Sure. Right now it is setup to only control boost at WOT. When you are at anything less than WOT, the boost target it set to 0, so you make only the wastegate pressure. Without this, some smaller turbos would make too much boost while in closed loop at part throttle and the engine would go lean. With this simple control, the boost won't exceed your waste gate spring pressure (minimum pressure) until you floor it.
In future releases we are going to expand on this and make a full compensation table that allows you to smoothly tailor the amount of boost you get for the throttle position. For now, it works pretty well at being driveable and still perform.
so the plan is to be able to adjust the boost through out the rpm range in each gear in later software versions?
because that would be awesome
and the no partial throttle boost feature is nice too
2004 black srt4
performance mods:
FM 3inch dual exhuast (no cat)
FM wga
exhuast depot hard pipes
greddy type s bov
msd wires
k&n cold air
evil creations bfmic
2 bwoody catchcan
ptp checkvalve
bwoody mm and tranny mount
dcr oil modifier
dcr power shift fluid
exterior mods:
clear third brake light
3d taillights
clear side markers
black eye lids
painted stock wheels
aftermarket antenna
treydoggnrhs is offline   Reply With Quote
Old 06-01-2009, 10:46 PM   #62 (permalink)
Member Number: 56991
Sorry if this is a repeated question, when will the software be online to flash the WOT BOX to a Boost Box
99.9% Stock!
RaiedZ is offline   Reply With Quote
Old 06-01-2009, 10:49 PM   #63 (permalink)
Member Number: 25854
Trader Rating: (95)
Yes. The capability is in there now, I just need to add tables to make it adjustable.
Old 06-01-2009, 10:50 PM   #64 (permalink)
Trader Rating: (95)
Software is here:
http://www.npcompleteperformance.com..._GUI_v1.21.exe
We just need to post up the instructions to show you how to rewire it to make it work. Those should be done and posted tomorrow.
Old 06-02-2009, 12:02 AM   #65 (permalink)
Turbolag87's Avatar
Member Number: 6491
how many boxes do i need if i want wot/2step/boostbox? cause i need all three.
Second ?, is there a bigger discount if i order all 3?
Thanks
F&F Stage III 47lb turbo
Returnline
AGP WGA,
Rolling thunder Race head
11.40@125mph 26psi and no boost leak
New times with new race head coming soon
www.cementwork.ca
Turbolag87 is offline   Reply With Quote
Old 06-02-2009, 12:38 AM   #66 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Should be fine. Which wiring do you have? The only thing I would recommend for the WOT Box is to swap the clutch switch input and add the crank position sensor input, if you are running the really old wiring. That way you can run the latest WOT Box software. The ignition coil wiring does not matter as much. Any of the options will work.
Yeah I'm running the original wiring config. If memory serves me correctly, if I just swap the clutch input to the crank position sensor, I'll have the 2-step feature without the fuel cut right?
Old 06-02-2009, 12:39 AM   #67 (permalink)
ziggo0's Avatar
Member Number: 63759
Per gear boost is quite sexy...but if you tune for say 20psi...and run like ...5psi/10psi/20psi....wont you run super rich in 1st & 2nd?
Flame Red 2004 SRT-4
Stock PCM, DTEC FC, RC 750's Returnless, 100% e85, Kinetic WGA, Stock Turbo @ 21/15, Custom 3" Turbo Back to Single Exit, Pwerks Race BFMIC, Solid Cold Side Pipe w/ HKS SSQV BOV, AEM SRI, 180F Thermostat, NGK 4306 @ 0.035, MSD 8.5mm Plug Wires, Coil Pack Heatshield, STS, Aeroforce Scangauge, AEM Wideband, Catch Can, "Big" 3 Grounds, Secondary Coil Pack Ground, Lightweight Battery
Old 06-02-2009, 12:40 AM   #68 (permalink)
morgantj13's Avatar
Member Number: 47175
Nice, seems pretty simple to setup...do we change any of the lines going to the turbo? Also, did any orders placed today get shipped out? I can't wait to install and try it out!
Old 06-02-2009, 12:45 AM   #69 (permalink)
morgantj13's Avatar
No, the stock PCM will alter fuel/air based on the boost it sees/what psi the turbo is making
Old 06-02-2009, 12:46 AM   #70 (permalink)
jas72's Avatar
Member Number: 69264
huh, now i assume it wont work with the DSP boost feature?? since it uses PCM control boost?? i have my boost turned up with my DSP, so i guess i wont need a boost box, but man is that an awesome toy!! or do i need to sell my DSP...lol thanx!! great job!!
2003 SRT-4: Stage 1
Spring mod: spike 22, holds 17 redline, AEM 3"cai & W/B, Greddy TT, DC strut bar. Mopar STS, MSD 8.5mm plug wires, Mopar Bov, Mopar stg.1 springs, Boomba solid mounts, catch can, NGK #4360, FPR, custom eyelids, Mitsu check valve, JBS Hard pipe, HP Racing 3" TBE, stock turbo and I/C..
jas72 is offline   Reply With Quote
Old 06-02-2009, 06:49 AM   #71 (permalink)
Trader Rating: (95)
Thanks
Just 2. You need a WOT Box to get the 2-step and no lift shift and you need a Boost Box to get the boost control.
We are offering a combo discount if you order both right now. The total is $330 + $9.99. If you ordered them separately, they'd be $189 + $9.99 + $169 + $9.99.... So you are saving almost $40 by ordering both now.
Old 06-02-2009, 06:58 AM   #72 (permalink)
Trader Rating: (95)
Yes, yellow wire to the cam position sensor. Green wire to the clutch. And yes, you will have ignition cut only.
Old 06-02-2009, 07:01 AM   #73 (permalink)
Trader Rating: (95)
It will work with the DSP or any other tuner. It doesn't use the PCM to control boost. It directly controls the WGA solenoid to control boost, just like other EBCs. So, it will take the boost control away from the PCM / DSP, but everything else remains under the control of the PCM / DSP.
Old 06-02-2009, 09:07 AM   #74 (permalink)
Member Number: 28737
Trader Rating: (82)
Was anything ever figured out to run a different solenoid. I took mine out and really didn't want to try to wire them back in if I could just use a different solenoid to make this work
Token Boomba Racing SRT-4
Maddog STS Info
taco is offline   Reply With Quote
Old 06-02-2009, 09:09 AM   #75 (permalink)
Trader Rating: (95)
You can use whatever solenoid you want. The Boost Box can drive up to 30 amps, so anything will work.
Page generated in 0.16542 seconds with 13 queries
