Old 07-28-2009, 05:41 AM   #541 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Q?
Is the wiring used for this the FINAL one? I'd appreciate it if I only had to solder this stuff once
If so, I'm definitely interested!!!
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 07-28-2009, 07:33 AM   #542 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by TmP View Post
Q?
I can't say for sure. Who knows what I'll think up next?
But, this one seems likely. The only question left in my head is how it will work on stock turbo cars without the TPS input. I have some code in there that should help prevent PTB without the TPS, but I can't know for sure until we try it on a stock turbo car. It worked fine on my S3 car, but that is a bigger turbo.
Old 07-28-2009, 07:57 AM   #543 (permalink)
TmP
TmP's Avatar
Screw the stock turbo guys then
Old 07-28-2009, 08:09 AM   #544 (permalink)
Turbolag87's Avatar
Member Number: 6491
is the wiring all different?
F&F Stage III 47lb turbo
Returnline
AGP WGA,
Rolling thunder Race head
11.40@125mph 26psi and no boost leak
New times with new race head coming soon
Turbolag87 is offline   Reply With Quote
Old 07-28-2009, 08:17 AM   #545 (permalink)
Trader Rating: (95)
Only 1 wire is different. The TPS wire gets replaced with the TIP signal.
Old 07-28-2009, 08:29 AM   #546 (permalink)
streetsteve's Avatar
Member Number: 65363
Trader Rating: (18)
i got an e1 turbo but a stage 0 pcm with a diablo, i would like to test this out
e1 turbo, dsp, stage 2 injectors, stage 2 wastegate, rev it up traction bars, bfmic, stock map and tip, maxxfab 3inch o2 housin, 3inch side exit no cat, walbro fuel pump, aem sri, n2mb wot box w/ 2-step, n2mb boost box, taylor sparkplug wires, ngk iridiums, cold sided pipe w/ hks ssqv, aem wideband, eibach pro kit, mopar short shifter, booger bushings, solid m/m inserts, bwoody catch cans and checkvalve
streetsteve is offline   Reply With Quote
Old 07-28-2009, 08:44 AM   #547 (permalink)
White Mirage's Avatar
Member Number: 72163
Subscribe so I can find this later
White Mirage is offline   Reply With Quote
Old 07-28-2009, 11:26 AM   #548 (permalink)
Knerrbo's Avatar
Member Number: 58462
E2 with stage 1 -- any possible issues?
Knerrbo is offline   Reply With Quote
Old 07-28-2009, 11:29 AM   #549 (permalink)
Trader Rating: (95)
Shouldn't be a problem. You'll need a 3 bar map if you want to boost over about 17 psi.
Old 07-28-2009, 11:50 AM   #550 (permalink)
Trader Rating: (18)
sweet where ca i download the new software
Old 07-28-2009, 02:12 PM   #551 (permalink)
Member Number: 54011
Trader Rating: (18)
just ordered mine, wont be installing for a few weeks tho. I hope everything is all squared away with the external wastegate install by then.
Masat03 is offline   Reply With Quote
Old 07-28-2009, 03:17 PM   #552 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
i vouch this works on a external gate...im running the old software but its the only difference will be using the tip vs the map...so that adjusting the wastegate prob will not change much as far as "if it will work"
it will work .
bribri is offline   Reply With Quote
Old 07-28-2009, 04:49 PM   #553 (permalink)
morgantj13's Avatar
Member Number: 47175
HEY!!! Dont hate on my little baby turbo lol...
maybe once the software is up, ill change my lines around and try out the newest software...i dunno tho, my setup is working great right now-maybe on the weekend ill try it out and post up(casue ive got stock turbo) assuming the new sw gets released
Old 07-28-2009, 11:10 PM   #554 (permalink)
Trader Rating: (95)
Test release of the new software....
http://www.npcompleteperformance.com..._GUI_v1.24.exe
wiring instructions:
http://sites.npcompleteperformance.c...LLERMANUAL.pdf
Ignore the tuning guide in that document.... I have to update it...
Old 07-29-2009, 12:33 AM   #555 (permalink)
Member Number: 31376
Trader Rating: (12)
Default lets do this...
I just happen to check the forums and lookey what I found.. I assume this is just a screen shot of what the newer software will look like? Spring pressure huh? When will we be able to download the finished version? Looks good though..
[x] MSD wires
[x] MBV
[X] Eibach pro kit
[ ] FM Wastegate (hit me up if your selling)
[X] N2MB boost box (you guys need this!)
I've modded/demodded this car twice in an attempt to sell her but just couldn't do it. 3X a charm???
allaboutboost is offline   Reply With Quote
Page generated in 0.26524 seconds with 13 queries
