Old 07-09-2009, 09:51 PM   #481 (permalink)
Member Number: 25854
Trader Rating: (95)
Sounds like a good setup for the Boost box. We have a few tricks up our sleeve to make it better with the next software release...
Old 07-10-2009, 12:55 AM   #482 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (78)
<--- can't wait
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 07-10-2009, 11:10 AM   #483 (permalink)
LIL CLIPS's Avatar
Member Number: 40425
i have a question and if you guys have answered it sorry... i have a agp wastgate if i get the boost box would it be easier to tune it with the stock wastegate?
LIL CLIPS is offline   Reply With Quote
Old 07-10-2009, 08:34 PM   #484 (permalink)
95neonman's Avatar
Member Number: 37749
So is there any final word on how this does on external waste gated cars? I think this would be a great thing to have on my car to help with traction.
11.53 @ 123 1.72 60' agp dbb 50trim w/sct
95neonman is online now   Reply With Quote
Old 07-10-2009, 11:15 PM   #485 (permalink)
Trader Rating: (95)
AGP wastegate should be fine, you just might need to adjust the preload down so that you can make lower boost. The initial preload that you set via the nut on the arm determines what the minimum boost you can make is.
Other than that, it should work fine.
Old 07-10-2009, 11:18 PM   #486 (permalink)
Trader Rating: (95)
Works on external wastegate cars. We've had a few guys get it dialed in just right on the external gate cars. No real difference than internal gate. We're still working on improving the tuning guide and the software to make it easier to tune, but other than that, you'll be all set.
Old 07-13-2009, 10:14 AM   #487 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
100% confirmed that it works on a external gate...i have no REAL issues boosting 9psi in 1st and ending at 20 in 4th...its a great product, just takes some getting used to...
just dont expect to plug it in and bam its perfect, it takes tweaking thats for sure, but the support is great...
i ended up turning off the learning and auto everything and made it 100% adjustable by me and i dialed in every boost duty cycle...no complaints once i got that squared away...
bribri is offline   Reply With Quote
Old 07-13-2009, 10:16 AM   #488 (permalink)
TmP
TmP's Avatar
Member Number: 59394
You'll need to send me some screenshots when I put mine on
Do you have a log?
A wot 1st through 4th pull log would be AWESOME!!!
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 07-13-2009, 11:48 AM   #489 (permalink)
Trader Rating: (95)
I spent the weekend working on some different boost control ideas. It will require a change in the vacuum lines and the wiring, but I think the results will be dramatically different. If everything works, it will require no tuning and no calibration table. If there is any tuning, it will be only one "knob" that adjusts the speed of the response. It will be a simple setting that adjusts the "aggressiveness" of the control.
Old 07-13-2009, 12:41 PM   #490 (permalink)
TmP
TmP's Avatar
That sounds kinda cool.
Kind of like the controller of the vari cool meth kit?
Old 07-14-2009, 01:28 AM   #491 (permalink)
morgantj13's Avatar
Member Number: 47175
awesome!
morgantj13 is online now   Reply With Quote
Old 07-18-2009, 11:10 PM   #492 (permalink)
Trader Rating: (95)
Ok, forget everything you know about the boost box. Take a look at this. This is a log from the very first run of the new software. No tuning, no learning. There aren't any adjustments that can be made or need to be made. Just really solid boost with the fastest spool possible and no overshoot....
Pretty cool. I'm really excited about it.
b.t.w. The spool might look slow, but that is probably just because of the time scale of the graph. I don't have it on this picture, but the solenoid is pegged on at 100% duty until right before the boost reaches the target. That makes sure it is spooling as fast as it can.
I should have more soon. I'll be posting up some beta software shortly. I have some more things to add to it.
Old 07-18-2009, 11:12 PM   #493 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Sweet!!!
Old 07-19-2009, 12:39 AM   #494 (permalink)
daniel427ss's Avatar
Member Number: 51325
ok im deff buying this thing,
srt stock motor mounts 4 sale
bunch of 350z parts for sale, cp pistons .020over, eagle rods, headgaskets, heads, timingcovers, etc. etc.
daniel427ss is offline   Reply With Quote
Old 07-19-2009, 01:14 AM   #495 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Quick curiosity. Will this system work on cars with an EMS? Or will it require the use of a factory PCM?
I have enjoyed the ability to do boost by speed with the AEM EMS, but I think boost by gear is a much better way of doing it! Or maybe a combination of both?
MY FAVORITE EQUATIONS:
Fuel Volume = (HP * BSFC) / (# of injectors * IDC)
CFM = C.I.D. * RPM * V.E. *.5 / 1728
P.R. = (PSI Boost + 14.7) / 14.7
HP = TQ * RPM / 5252
Page generated in 0.17975 seconds with 13 queries
