Old 07-06-2009, 08:23 AM   #466 (permalink)
Member Number: 25854
Trader Rating: (95)
We may end the introductory pricing at some point, but we'll let everyone know before we do.
We are also working on the software to try and eliminate the tuning. Of course, we'll post that software for free for everyone.
Old 07-06-2009, 10:45 AM   #467 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
The 2 settings is a big deal. HOM non HOM is a dramatic difference & the boost doesn't change.
11.9@117 so far.
Wiseman - Just cuz someone else has a fast car with the same parts as you, doesn't mean your car is fast.
Work harder, millions of people on welfare are depending on you.
srt4geezer is offline   Reply With Quote
Old 07-06-2009, 10:59 AM   #468 (permalink)
Trader Rating: (95)
Not sure what you mean.... You shouldn't have to change your boost on HOM....
Old 07-06-2009, 10:59 AM   #469 (permalink)
Trader Rating: (95)
oh, if you mean for traction... lowering boost while on HOM?
Old 07-06-2009, 11:43 AM   #470 (permalink)
srt4geezer's Avatar
Member Number: 910
Trader Rating: (13)
Bingo!
Old 07-06-2009, 10:51 PM   #471 (permalink)
Member Number: 73544
i have done hundreds of pulls and spent hours tuning and have done everything john has told me to do. still nothing. Its never consistent. 3-5 is set at 18 and when i finaly get it to just hit 18 in 3rd ( it falls very quickly to 14) 4th gear will boost plum to 26 and hit boost cut. i have tried everything i mean everything. i know i have drove john and jay crazy. im not trying to complain the boost box is just not for me. will you please refund my money and i will ship it back.
esr srt4 is offline   Reply With Quote
Old 07-06-2009, 11:20 PM   #472 (permalink)
Trader Rating: (95)
I'm sorry you haven't been able to get it to work. As I mentioned in my email, I think you need to lower the preload on your WGA. I think it is too high. Have you tried that?
If you want to return any of our products for any reason, you can always do so within the first 30 days. Just pack it up and mail back to us and we'll send you a full refund.
I sent you our address in response to your email.
Old 07-06-2009, 11:30 PM   #473 (permalink)
Trader Rating: (95)
Additionally, here is the first draft of the installation guide. Take a look over this:
http://sites.npcompleteperformance.c...LLERMANUAL.pdf
Old 07-07-2009, 04:57 AM   #474 (permalink)
i did turn my waste gate down and it would only go to 15 psi no matter what i did. i was trying to run 18. and i had 8 psi of boost with the boost box unplugged
Old 07-07-2009, 06:21 AM   #475 (permalink)
Turbolag87's Avatar
Member Number: 6491
What turbo are you running?
F&F Stage III 47lb turbo
Returnline
AGP WGA,
Rolling thunder Race head
11.40@125mph 26psi and no boost leak
New times with new race head coming soon
Turbolag87 is offline   Reply With Quote
Old 07-07-2009, 07:46 AM   #476 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
post of screen shots of your settings and cal table
bribri is offline   Reply With Quote
Old 07-09-2009, 12:12 AM   #477 (permalink)
its stock turbo. i will try to post the screen shots im borrowing my buddies lap top so i will see what i can do.
Old 07-09-2009, 12:21 AM   #478 (permalink)
Member Number: 27311
Default uhm
My car doesnt have a boost box on it, my car has the pcm out of the loop and spikes 23 ish holding 16ish to redline, and in fourth or fifth it kinda spikes to like 27ish (fully built ported stock turbo). Anyways my question is will your boost box cutout if i set it to like 23ish max or will it still give me full power just not let me go over 23ish (kinda like an external wastegate). And will this product work for me???
I was also under the impression that the boost box was your version of the electronc boost controller? You guys have both?
spool4u is offline   Reply With Quote
Old 07-09-2009, 06:48 AM   #479 (permalink)
Trader Rating: (95)
The Boost Box is an electronic boost controller.
If you set the overboost feature at 23 psi, when you hit 23 psi, the boost will cutout instantly, like you hit a wall. It will shutdown completely to save your motor. The overboost feature is there as a safety to shut things down if they are not tuned right.
If you tune it right, it should not spike like you have it now. It should only spike by a few psi and then settle to the target. How are you controlling boost now that you have such a huge spike?
The only other thing you will need is a 3 bar map sensor, if you want to make boost higher than about 17 psi. The stock 2.25 bar map sensor only reads up to about 18.5 psi, and you need about 2 psi of headroom for good control.
Old 07-09-2009, 06:17 PM   #480 (permalink)
Default i have stage 2
w/ je pistons and eagle rods
3 angle valve job plus ported head
stage 3 clutch from clutchmasters
Fully built ported turbo / mammoth manifold combo
Mopar Stage 2 w/o toys
Perrin high flow fuel rail
Walbro 255 fuel pump
MSD Coil
MSD Wires
NGK 2 step colder spark plug
Lineage Ground Wires
3" O2 housing (not yet installed)
3" turbo back Exhaust w/o cat
3" injen cold air intake
RPM 60mm throttle body
Custom 2.5 inch inner-cooler hard pipes
HKS Super-Sequential blow off valve
AGP inter-cooler 12 x 24 x 4-1/2
AGP wastegate w ptp spring
ptp check valve
Turbo Xs manual Boost Cont.
Greddy catch can
cooling mist water injection (never used)
Nitrous Express 75 shot
AGP solid motor mounts
180 t stat w/ 26 ibs cap
and to tune..
SRT EGT guage
AEM wideband
Apexi SAFC II
here is a list of my performance parts, i think thats all...
so i guess its that damb agp wastegate and turboxs boost controller.
I had a profec b electronic boost controller with the wireless button on the steering wheel but i couldnt get it to work so i sold it to some guy for a 100, find out it works fine just had it hooked up wrong
Page generated in 0.17185 seconds with 13 queries
