Old 06-29-2009, 03:50 PM   #436 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
i just posted up some tips on this matter in th other thread that morgan started
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 06-29-2009, 04:03 PM   #437 (permalink)
daniel427ss's Avatar
Member Number: 51325
has anyone ran this with a s20g???? i know iknow this turbo sucks but its been decent. the only thing is i can't boost above 21, can this box do it? internal wastegate that is.
srt stock motor mounts 4 sale
bunch of 350z parts for sale, cp pistons .020over, eagle rods, headgaskets, heads, timingcovers, etc. etc.
daniel427ss is offline   Reply With Quote
Old 06-29-2009, 04:04 PM   #438 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
thanks for your response (and i read the other thread)...when this rain clears up ill start testing this sometime this week
when i save a setup, it saves the duty cycle to right? as well as loading a saved one?
bribri is offline   Reply With Quote
Old 06-29-2009, 04:06 PM   #439 (permalink)
Member Number: 38189
were both waiting for the rain to clear up lol
rico's-srt is offline   Reply With Quote
Old 06-29-2009, 04:06 PM   #440 (permalink)
Member Number: 25854
Trader Rating: (95)
Yes, if you click read before saving.
Old 06-29-2009, 04:07 PM   #441 (permalink)
Trader Rating: (95)
Also, it saves on the box if you click write.
Old 06-29-2009, 04:07 PM   #442 (permalink)
Trader Rating: (95)
If you have a 3 bar map sensor, you can do it. The stock one won't go that high.
Old 06-29-2009, 04:22 PM   #443 (permalink)
bribri's Avatar
Trader Rating: (10)
also phrozen, is the duty cycle based off the wastegate? wastegate spring? solenoid? or the turbo?
Old 06-29-2009, 04:24 PM   #444 (permalink)
yeah i have the 3bar map sensor, (stg2) i currently have a PIT electronic boost controller(i dont know if ur familiar with it Boost Control+) but never really did good to move the gain n % of i dont remember what else, i only spike 26 27 but then goes back to 21 always n sucks. (this is at a target of 8psi)
ive always wanted at least 25 26.
Old 06-29-2009, 04:53 PM   #445 (permalink)
Trader Rating: (95)
The duty cycle is the duty cycle that drives the solenoid.
75% duty cycle means the solenoid is open 75% of the time and roughly allows 75% of the full airflow through....
Old 06-29-2009, 04:54 PM   #446 (permalink)
Trader Rating: (95)
I just looked at it a bit, but it sounds like your wastegate is coming open at high RPM, more than a fault of the EBC.
Ours might do similar things, or it might do better. It depends if your wastegate can handle the pressure. Internal or external gate?
Old 06-29-2009, 05:13 PM   #447 (permalink)
bribri's Avatar
Trader Rating: (10)
So technically, if you run the stock solenoid and a AGP wastegate (big turbo guys)...we should have the same duty cycles for boost even if the turbo is different...correct?
Old 06-29-2009, 05:22 PM   #448 (permalink)
Trader Rating: (95)
No, probably not. They might be close, though. The actual numbers will car specific, temperature specific, altitude specific... That's why it learns and adjusts...
Old 06-29-2009, 05:42 PM   #449 (permalink)
internal, how can i know if my wastegate can handle it
Old 06-29-2009, 05:44 PM   #450 (permalink)
Trader Rating: (95)
Hard to say. You'd have to go by what others have done with that particular turbo and WGA, or try an MBC and see if it holds the boost.
Page generated in 0.17221 seconds with 13 queries
