Old 06-01-2009, 02:01 PM   #31 (permalink)
bryan9097's Avatar
Member Number: 48384
Trader Rating: (19)
now....... where did I put that $330.
AGP S3 Delta 44, Walbro 255, S2 WO Toys, PTP CV,3" exhaust depot, PTP HS, Greddy TT, AGP dog bones & Trans mount, 18" Sports Max Racing rims, Mopar Performance Clutch, Mopar BOV, Mopar SS, Mopar CAI, Mopar oil pressure gauge, Mopar Volt Gauge, cooling mist W/I (trunk mount)using Cool fuel, BWoody CC, CBD B&C Pillars, CBD fog lights inserts, BFG 225/40/18, Magnaflow 3 in/out muffler, Eibach sportline springs, AEM UEGO, Darksyde ported intake & TB.
bryan9097 is offline   Reply With Quote
Old 06-01-2009, 02:19 PM   #32 (permalink)
Member Number: 45202
Subscribed, I will hopefully be ordering this sometime soon.
STOCK
ghice007 is online now   Reply With Quote
Old 06-01-2009, 04:00 PM   #33 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Phrozen/Jay-
I have the OG style WOT box. How (if any way) can I make the install simpler?
Old 06-01-2009, 05:06 PM   #34 (permalink)
morgantj13's Avatar
Member Number: 47175
it'll probly be in the insturctions, but if you have an adjustable wga, what adjustment do you leave it at?
phrozen-what wga are you using?
Old 06-01-2009, 05:10 PM   #35 (permalink)
winker2112's Avatar
Member Number: 14625
Ordered. If it doesn't work with ext gates, then I i guess I'll just have to go back to stock turbo
winker2112 is offline   Reply With Quote
Old 06-01-2009, 05:11 PM   #36 (permalink)
boogaloo shrimp's Avatar
Member Number: 64459
Trader Rating: (15)
The second boost map for switching with the button is not in there yet, but I should be able to put that one in the software this week. That feature is pretty easy to put in the code.
The boost targets are programmable for each gear. Once set, the boost controller will try to maintain that boost setting for each gear across all RPM, including up to redline. It is now holding boost to redline better than it shows in the video. We will post up a new video soon.
The amount of boost spike will be determined by how high you have the proportional gain set. If the gain is higher, you will get more boost spike and slightly faster response. If you drop it lower, you will have less boost spike and a slightly slower response.
sweet ...thats 100% wat i was looking for...fuk the profec B....lol great work
so that button on the box will be a 1/2 boost chart switcher?
Quote: Originally Posted by killaneon View Post
boogaloo is always good for a lulz
"i need you, like a little boy's salad needs some neverland ranch"
......SRT-4.....the domestic with an identity crisis.......
Stage2 @ 20psi + bolt-ons out the @55
my quest for 250mph in the quarter mile
boogaloo shrimp is offline   Reply With Quote
Old 06-01-2009, 05:13 PM   #37 (permalink)
Trader Rating: (15)
that's dedication at it's best.....base your entire setup around n2mb products lol....
if it doesnt work, sell me the box! hows 120 shipped sound?
Old 06-01-2009, 05:14 PM   #38 (permalink)
SRTMIAMI's Avatar
Member Number: 54645
Trader Rating: (12)
very nuice! n cheap! nice product!
GT3076R-AEM EMS-DP VARI-COOL
WWW.MYFLORIDASRT.COM
SRTMIAMI is online now   Reply With Quote
Old 06-01-2009, 06:03 PM   #39 (permalink)
Member Number: 38189
ill be placing an order at the end of this week
rico's-srt is offline   Reply With Quote
Old 06-01-2009, 06:29 PM   #40 (permalink)
winker2112's Avatar
I was serious... n2mb has only come out with great stuff that I've endorsed since the beginning.
you got a better shot of buying my dbb 50trim, than any blue box outta my car.
Old 06-01-2009, 08:42 PM   #41 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
Interested in seeing how it does with externally gated turbos. I'm anxious for results!
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 06-01-2009, 08:56 PM   #42 (permalink)
goats srt's Avatar
Member Number: 47689
X2 cause the dtec is alittle pita
look in my for sale thread
selling good stuff check it out
goats srt is online now   Reply With Quote
Old 06-01-2009, 09:17 PM   #43 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by Philth View Post
Ordered. (Duvall)
Awesome. Thanks! It should ship out right away.
Old 06-01-2009, 09:19 PM   #44 (permalink)
Trader Rating: (95)
Phrozen/Jay-
All the WOT Boxes (and Boost Boxes) are the same, so just follow the latest instructions from our website. Once you have it installed, load our latest software, also from our website and you'll be as good as brand new.
Old 06-01-2009, 09:28 PM   #45 (permalink)
Trader Rating: (95)
I'm using the stock S3 WGA. You'll need to adjust the WGA down until you get to the minimum boost you want to run. Mine is still set as it came stock and the minimum boost I get out of it, even without the boost controller running is 8 psi. So, I need to loosen it a bit to get it down more. But, if you loosen it too much, you won't make full boost on the top end. So, it is a bit of a tradeoff.
I would say you want to start with the boost controller disconnected and adjust the WGA until you get the minimum boost you want to make. I.e. just low enough so that you can get traction in first gear. Then hook up the box and let it learn the duty cycle required for the high end. If you max out the duty cycle and still aren't making enough boost, then you'll have to go back and tighten up the WGA a bit.
Page generated in 0.18094 seconds with 13 queries
