Old 06-22-2009, 10:58 PM   #376 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by TmP View Post
Can I consider myself a beta tester?
You're an early adopter for sure. Hopefully not beta after 22 software releases.
But, there's still probably 22 releases to come... hahahah. Always room for improvement. I'm never satisfied.
Old 06-23-2009, 09:33 AM   #377 (permalink)
Member Number: 51439
Trader Rating: (13)
Quote: Originally Posted by never2muchboost View Post
probably not but there is some noise on that circuit when the wipers are on however if your wipers are on i dont think boost control is an issue lol
haha yeah good point. I just wanted to make sure it wouldnt mess anything up. For example, with the wideband goes out, if I run the car for to long without it functioning, then it will screw up my o2 and I have to buy another one...
AGP 50 Trim, AGP 38mm Wastegate, Needswings v5, Mopar Exhaust, BFMIC, Bwoody Motor/Trans Mounts, 55mm Ported Throttle Body, Injen Cold Air Intake, Granatelli Wires, HKS SSQ BOV, LC-1 Wideband, DTEC FCBC, 750cc Injectors, Walbro 255, AGP Hardpipes, AGP Wastegate, Bwoody Catch Can, Check Valve, Mopar STS, Coolingmist Meth/Water Injection, Fuel Pump Re-Wire, Diablosport Predator
low0r is offline   Reply With Quote
Old 06-23-2009, 09:44 AM   #378 (permalink)
Trader Rating: (95)
There won't be any problems like that. Worst case you just wouldn't have boost. But even that is unacceptable in my mind. Let us know if you have any problems with noise and the Boost Box not working on that circuit. I haven't seen any yet, but you never know.
Old 06-23-2009, 04:54 PM   #379 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
Trader Rating: (40)
ooohhhhh...i want to be a beta lol
04 Neon SRT-4 - lifetime project
99 R1 - DD
02 Night Train
04 XL883
00 B5 Passat - POS!
KrazyRdR83 is offline   Reply With Quote
Old 06-23-2009, 04:58 PM   #380 (permalink)
Trader Rating: (95)
It's not in beta...
Old 06-25-2009, 03:53 PM   #381 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Is this what I need?
KLICK
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-25-2009, 03:59 PM   #382 (permalink)
tusamni's Avatar
Member Number: 35294
Trader Rating: (32)
Looks like it, yep.
tusamni is offline   Reply With Quote
Old 06-25-2009, 04:04 PM   #383 (permalink)
TmP
TmP's Avatar
Even though it says 24V and 125 VACUUM???
Me = confused
Old 06-25-2009, 04:12 PM   #384 (permalink)
Trader Rating: (95)
Me = confused
No, 24V valves won't work. Needs to be 12V. And then, the standard MAC valve 12V part isn't rated for underhood installation. There are a few upgrades required to make it waterproof and capable of high heat.
I would say use the stock solenoids. You can get them for $33...
Old 06-25-2009, 04:15 PM   #385 (permalink)
Trader Rating: (95)
Speaking of reducing confusion, what do you think of these 4 diagrams?
External gate, MAC valve:
External gate, Stock solenoid:
Internal gate, MAC valve:
Internal gate, Stock solenoid:
Justin is a mad crazy CAD guy....
Old 06-25-2009, 04:21 PM   #386 (permalink)
TmP
TmP's Avatar
They are cool, but if I leave the top port to atmosphere, how in hell am I gonna be able to run 23 psi on a 9psi spring???
Old 06-25-2009, 04:22 PM   #387 (permalink)
Trader Rating: (95)
It should work. I believe winker is running something like that right now...
Old 06-25-2009, 04:26 PM   #388 (permalink)
TmP
TmP's Avatar
Huh... interesting.
So the 'noid is a 1:1 replacement for the MBC then. Right?
Old 06-25-2009, 04:29 PM   #389 (permalink)
Trader Rating: (95)
Huh... interesting.
Yes, we're plumbing it in an MBC would be. Can you do 23 lbs on your 9 lb spring now with an MBC? If so, then this should work the same. But, you'll also be able to make down to 9 psi in the lower gears.
Old 06-25-2009, 04:31 PM   #390 (permalink)
TmP
TmP's Avatar
I'm afraid that I won't hold boost to redline that way.
I actually bought the boost box because I thought that it would direct pressure to the top to shut the gate too... Didn't someone post a pic like that?
Page generated in 0.16825 seconds with 13 queries
