Old 06-19-2009, 07:30 PM   #346 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
So this can store more than 1 map right? If not that should be a must!
I ordered it already but I really hope you can
bribri is offline   Reply With Quote
Old 06-19-2009, 11:18 PM   #347 (permalink)
harvboi05's Avatar
Member Number: 30703
not just yet, the next SW release will allow us to do so.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Old 06-20-2009, 01:26 AM   #348 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (100)
I will be making a purchase soon
Can someone post a vid of the extermal WG ?
bitts is offline   Reply With Quote
Old 06-20-2009, 02:34 AM   #349 (permalink)
Member Number: 31376
Trader Rating: (12)
Default tables for different setups
I think one guy has posted his settings for his particular setup, but wish others would as well. Knowing the overboost;kp;ki;etc.. settings for different setups would be nice. Then one could just look up their mods, punch the numbers in, and not worry about hitting boost cut due to overboost. Also would like to remind the newbies to remember A/F ratios when messing with WG preloads and max boost settings. Just because your aftermarket WG allows 20+ psi, doesn't mean your injectors/fuel system can compensate for it. Congrats to N2MB for their efforts and awsome customer support. This will be my fathers day gift from my two girls.
P.S.
For faster installs, look for the splice connectors at your local hardware store. Of course the critical wires need to be soddered for ultimate reliablility.
[x] MSD wires
[x] MBV
[X] Eibach pro kit
[ ] FM Wastegate (hit me up if your selling)
[X] N2MB boost box (you guys need this!)
I've modded/demodded this car twice in an attempt to sell her but just couldn't do it. 3X a charm???
allaboutboost is offline   Reply With Quote
Old 06-20-2009, 08:11 AM   #350 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Used the splicers for the WOT box install.
No issues so far
How much of the wiring can be done in cabin if you have a WOT box?
I think just power, ground and TPS... right?
The rest is MAP and the Noid. So that still needs to go to the bay.
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-20-2009, 11:02 AM   #351 (permalink)
Member Number: 25854
Trader Rating: (95)
No issues so far
Power goes to the windshield wiper fuse in the passenger compartment. That way it is on whenever the key is on, unlike the WOT Box. It makes it easier to change the settings without having to run the engine.
TPS can come from the WOT Box. Ground is at the fuse box.
Old 06-20-2009, 11:07 AM   #352 (permalink)
Trader Rating: (95)
P.S.
Thanks and happy father's day!
We do recommend that you don't use those splice connectors. Pretty much all the wires are critical. If they are disconnected, then unpredictable things can happen.
The only wire that can become disconnected without causing a problem is the OBD wire. Then you would just loose the boost by gear. But, it would be hard to diagnose a problem like that if it was intermittently coming disconnected because it might cause the boost to jump around to the wrong settings.
Old 06-20-2009, 08:49 PM   #353 (permalink)
Trader Rating: (12)
Default Scratch that then...
Ok, going to have to spruce up the old sodering skills. That is good info to know. One loose wire and KABOOM? No thanks. It looks like I might be the first one to try this with the ole spring mod. Going to wait on the FM wastegate until I see how this works. I think the stock wastegate is only good for 16lbs? Want to be near the max of the solenoid at least (19.2 lbs?)
On a side note, how difficult would it be in the future to design these to come off of the OBDII port like the diablo or such? I am in no way knocking the install cause it is not that hard, but just curious as to how involved is it to be able to plug into this port and control parameters there?
Old 06-20-2009, 09:39 PM   #354 (permalink)
TmP
TmP's Avatar
I would guess it's next to impossible, as you control the noid in a way it wasn't meant to be.
Also, if you flashed a different boost map on the stock ecu, like with a dsp, how would you switch it, let alone save another one?
I think you won't be able to work around having a separate ecu instead of just a flash.
BTW, why do you type everything bold? Kinda annoying
Old 06-20-2009, 10:13 PM   #355 (permalink)
Trader Rating: (95)
You got it. Yeah, it would be an entirely different product. You're referring to an ECU flash, which will always be limited to basically what the original ECU was capable. An ECU flash also takes many man years to develop and usually some inside information from the OEM. That's why they end up being pretty expensive.
Instead, we have developed an EBC, which controls the boost completely independent of the ECU. That way we are not limited to what the stock computer can do. It can do pretty much anything we want with boost. We do make use of the stock ECU to give us some information, but generally we don't need it. This way we can also make the EBC work on other cars pretty easily.
Old 06-20-2009, 10:23 PM   #356 (permalink)
TmP
TmP's Avatar
Has mine shipped already?
I want it sooo bad
btw. Is c) ricer mode implemeted yet? I WANT IT
Old 06-20-2009, 10:31 PM   #357 (permalink)
Trader Rating: (95)
I want it sooo bad
PM me your email address and I'll look it up. You will also get an email from Paypal with the tracking number when it ships.
Old 06-20-2009, 10:46 PM   #358 (permalink)
TmP
TmP's Avatar
Oh, ok. Never mind then.
Old 06-21-2009, 10:39 PM   #359 (permalink)
Trader Rating: (12)
Default makes since
True, never thought of it like that. Don't know why it's always in bold. I don't check the box for it? I am not quite up with the lingo, but doesn't this mean I'm yelling all the time? HA! Makes since due to my older age and hearing loss.
Old 06-22-2009, 05:03 AM   #360 (permalink)
TmP
TmP's Avatar
That's better
Page generated in 0.16875 seconds with 13 queries
