Old 06-17-2009, 10:16 PM   #301 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by ToMuchBoost View Post
When are you coming out with a softwere update that will let us change the gear ratios (need to make this work with an auto trans)...
It's in the next one. I wrote that in this weekend along with a bunch of other improvements. I should be posting it soon. It needs a bit of polishing and testing.
Old 06-17-2009, 10:22 PM   #302 (permalink)
ToMuchBoost's Avatar
Member Number: 35620
Trader Rating: (78)
Nice....!
FYC Racing
Build Thread Here
ToMuchBoost is offline   Reply With Quote
Old 06-18-2009, 05:43 AM   #303 (permalink)
winker2112's Avatar
Member Number: 14625
Quote: Originally Posted by TmP View Post
Hey, you have me hooked already
I just don't like the stock noids because they look and that snake nest of lines... OMG
Hate it.
I think you are a bit confused on the whole stock solenoid thing....
The stock solenoids come in a pack of three solenoids with a bundle of vac hoses taking up space in a stock srt4 engine compartment.
The boost box does not require you to run this stock set up.
All it needs is for you to use one of the three solenoids hooked up between turbo and gate like an mbc. The other solenoids, and vac lines that you already removed can stay in the garbage. So all you'd have to do is find space for one of those solenoids, which is not much bigger than a mbc. So keeping it out of view should not be a problem. In my car it's behind the where the battery should be (i have a meth tank the size of a battery where the stock battery sits). Honestly you wouldn't find it if you were looking for it.
So people who think this means going back to pcm controlled solenoids you are mistaken. This box just gets wired straight to the one solenoid and thats all. And it works!
Hope that clears some things up.
winker2112 is offline   Reply With Quote
Old 06-18-2009, 06:05 AM   #304 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Huh... interesting
Got a DSP log of yours in action?
Like WOT 1st - 2nd - 3rd ?
That'd be the awesomness
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-18-2009, 06:45 AM   #305 (permalink)
KrazyRdR83's Avatar
Member Number: 55270
Trader Rating: (40)
so you can use ANY one of 3 solenoids?
04 Neon SRT-4 - lifetime project
99 R1 - DD
02 Night Train
04 XL883
00 B5 Passat - POS!
KrazyRdR83 is offline   Reply With Quote
Old 06-18-2009, 06:52 AM   #306 (permalink)
TmP
TmP's Avatar
If you use the stock solenoid, do you plug it in and then splice into it, or do you cut the connector off and use it solely for the box???
Old 06-18-2009, 07:34 AM   #307 (permalink)
Trader Rating: (95)
Yes, I believe they are all the same.
Old 06-18-2009, 07:35 AM   #308 (permalink)
Trader Rating: (95)
The connector gets cut off a few inches back and is connected solely to the Boost Box. One lead goes to ground, the other lead goes to the Boost Box output.
On the harness side going to the PCM, a resistor gets connected to the two wires.
Old 06-18-2009, 07:38 AM   #309 (permalink)
TmP
TmP's Avatar
Get it.
So you basically do the no solenoids mod and reuse one noid as the boost controller, just like an AEM would do it.
Old 06-18-2009, 07:41 AM   #310 (permalink)
Trader Rating: (95)
Get it.
Well, you don't have to get rid of your other solenoids. I still have all of mine.
But, the other ones won't matter for this. They may matter for other things, though. You'll need the surge solenoid if you still have the stock surge valve...
Old 06-18-2009, 07:58 AM   #311 (permalink)
TmP
TmP's Avatar
D44
Old 06-18-2009, 12:29 PM   #312 (permalink)
morgantj13's Avatar
Member Number: 47175
what line should I tap into for the 3bar sensor? I dont use my redline(that goes to tip) so should I just use that one?
Old 06-18-2009, 01:11 PM   #313 (permalink)
04blusrt_4's Avatar
Member Number: 60369
You should really tap into a boost AND vacuum source, the redline only sees boost. I would find a spot off the throttle body line, T into that line.
*NE 400 Club*
Old 06-18-2009, 03:31 PM   #314 (permalink)
Trader Rating: (95)
Sounds about right.
Although, I suppose we don't really need to know about vacuum. The boost controller won't do anything while you are in vacuum. But, that is typically how it is done.
Old 06-18-2009, 04:48 PM   #315 (permalink)
harvboi05's Avatar
Member Number: 30703
has anyone running a big turbo adjusted their calibration table for quicker spool yet?
care to share ur calibrations?
i am running the 12psi spring, and was gunna adjust the table to 0% duty cycle until about 8psi or so and then level out into the default duty cycles by 12psi.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Page generated in 0.18365 seconds with 13 queries
