Old 06-01-2009, 06:50 AM   #16 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by rolla4now View Post
can the wot box/2step combo be used with this...?
if so, how would the wiring differ?
The WOT Box gets wired into the ignition coils, TPS, crank position sensor and clutch switch.
The Boost Box gets wired into the WGA solenoid, TPS, MAP sensor and OBD.
Full installation instructions will be posted hopefully tonight.
You can use the WOT Box and Boost Box at the same time, you just need two boxes. That is what I have on my car right now.
Old 06-01-2009, 06:53 AM   #17 (permalink)
Trader Rating: (95)
Quote: Originally Posted by xXSilentScreamXx View Post
will this replace my greddy profec and do i just type in how much psi i want to run and do i have to have pcm controlled boost?
Yes, it can replace your existing boost controller.
It does not use the PCM to control boost. It manually controls the WGA solenoid to adjust how much boost the turbo makes, just like other EBCs do.
Old 06-01-2009, 06:54 AM   #18 (permalink)
Trader Rating: (95)
Quote: Originally Posted by boogaloo shrimp View Post
answered above
appparently they wire the same and the boxes can convert from boost to wot.............
thats how i took it
The wiring is different, but the box is the same. You can turn one into the other just by reloading the software and rewiring. But, you can't do both at the same time. There are not enough wires.
Old 06-01-2009, 06:59 AM   #19 (permalink)
turbojack's Avatar
Member Number: 11814
Trader Rating: (121)
So an a existing WOT box user can flash/install boost box software onto the existing WOT box to check this out? Wiring will need to be re-done but I understand that part.
Old 06-01-2009, 07:05 AM   #20 (permalink)
Trader Rating: (95)
That is correct.
You can grab an extra wiring harness from our website if you want to make it easier to install. N2MB Racing
Old 06-01-2009, 09:26 AM   #21 (permalink)
Pinebox's Avatar
Member Number: 7440
NICE!!!
how can I spend $330 and not let the wife know.....
*edit*
For the $330, does that include the WOT box w/2-step AND the boost box?
Pinebox is offline   Reply With Quote
Old 06-01-2009, 09:48 AM   #22 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
Wooow
NemoFoss is offline   Reply With Quote
Old 06-01-2009, 09:50 AM   #23 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
Oh it's definitely gonna need programmable Gear Ratios. My accel shafts and dogboxs need that function.
Old 06-01-2009, 10:27 AM   #24 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (29)
Hey guys, quick question.
How does this work with Mopar Toys on the Stage 2 & 3 kits? Leave it in DAB 3?
Old 06-01-2009, 10:56 AM   #25 (permalink)
Trader Rating: (95)
No problem.
Old 06-01-2009, 10:57 AM   #26 (permalink)
Trader Rating: (95)
Your DAB setting won't matter. You can set it anyway you want. The PCM won't be controlling boost.
Old 06-01-2009, 10:59 AM   #27 (permalink)
Philth's Avatar
Trader Rating: (29)
Snaps.
Old 06-01-2009, 11:00 AM   #28 (permalink)
littlepvt's Avatar
Member Number: 3267
Trader Rating: (45)
What he said lol I'm planning on getting the Dogbox and need that feature.
On Order: Precision GT4094r, t-4 Pro Series manifold, 4in exhaust, 3in piping from turbo to TB, Avenger Pro-Mod head, 8 injector IM, DCR intercooler w/ 3in inlet and outlet, Dogbox
DCR: 2.6 over 40, Input Shaft, CP Ignition,
Mopar: Sway Bars, S3R CO, Ti Strut Bars, RCAs, Camber Plates
Rage-Tek: LCA, HTOB, Triple Fuel Pumps, 3/4 fork
ClutchMaster: Twin Disk
AEM: EMS w/ 3.5 BAR sensor
Boomba: All 3 MM
littlepvt is offline   Reply With Quote
Old 06-01-2009, 11:03 AM   #29 (permalink)
Philth's Avatar
Trader Rating: (29)
Ordered. (Duvall)
Old 06-01-2009, 01:01 PM   #30 (permalink)
morgantj13's Avatar
Member Number: 47175
JUST ORDERED A BOOST BOX!!!!!!
Awesome guys, you did a great job with the wotbox/2step so this should be amazing!!
Page generated in 0.16987 seconds with 13 queries
