I'm lost on this resistor thing. What if your BIG Turbo and Stage 1 PCM. Right now I have 0 vacuum lines running off of that solenoid with the wire harness going to it. The thing with all the pink/blue/black/green vac lines are all disconnected as you don't need them.
You'll need to hook up those vacuum lines again. Just the green and black ones going to the WGA solenoid.
The resistor goes on the solenoid line to the PCM, after it has been cut to prevent the check engine light from coming on once the PCM no longer has control over the solenoid. You don't need it, but it is nice to do.
Question - for the TPS wire and if we already have a WOT box installed, can we tap into the TPS wire for the WOT box right there in the cabin, or do we need to run a wire all the way to the TPS again?
Yes, you can use the TPS wire from the WOT Box. That is what I did.
BADASS!!!!! I just checked the mail and it was in there!!!! Ill be installing tonight(probly like 11 or 12 lol, but it will be done tonight
Heres a pic, but it looks just like the wot box!
awesome! ill be up for a little while so if you have any questions you can grab me on email at support@n2mb.com
that gets forwarded to my blackberry so if im awake ill respond
I just wrote the software for multiple maps. It will be in the next software release.
External gate results should be very soon.... One of the many external gate cars is bound to get it done first!
Sounds good.
So, you just push a button and switch maps or do you have to hook up the computer? The reason I'm asking is because I like having an electronic boost controller because I can set up low and high boost and switch between the two by hitting a button.
