Old 06-18-2009, 04:00 PM   #76 (permalink)
Member Number: 25854
Trader Rating: (95)
Quote: Originally Posted by harvboi05 View Post
does a previously installed code scrubber impact install in anyway? specifically the purple and yellow to yellow wire connection.
Nope. I have a code scrubber on my car. Actually, I have all 4 products on my car. Code scrubber, WOT Box, Boost Box, and Toybox 2.0.
You can attach the yellow wire before or after the scrubber. You can use the same splice.
I would recommend putting it at the splice after the scrubber, i.e. more towards the car harness, rather than towards the OBD port. That way the Boost Box will still function if you unplug the scrubber for some reason.
For reference, that should be the green wire:
Old 06-18-2009, 04:37 PM   #77 (permalink)
harvboi05's Avatar
Member Number: 30703
cool. you were just waiting for that question to pop up werent you?
i have all 4 boxes too.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Old 06-25-2009, 04:16 PM   #78 (permalink)
Trader Rating: (95)
What do you think of these 4 diagrams?
External gate, MAC valve:
External gate, Stock solenoid:
Internal gate, MAC valve:
Internal gate, Stock solenoid:
Justin is a mad crazy CAD guy....
Old 06-25-2009, 04:39 PM   #79 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Those diagrams look awesome....
So basically with either solenoid and external gate you hook up like its a MBC and don't run a compressor source to the top of the wg?
2004 SRT-4 BEE-OTCH!! <<Under Construction>>
AGP Delta 55, FIC 1150's, Magnafuel 625 etc...
SY04SRT4 is offline   Reply With Quote
Old 06-25-2009, 04:40 PM   #80 (permalink)
Trader Rating: (95)
Yes, that's what we've found to work well.
The other option would be to do it this way,
But, we haven't had as much luck with that setup.
Old 06-25-2009, 04:44 PM   #81 (permalink)
SY04SRT4's Avatar
Member Number: 3903
Awesome. Thanks for clearing that up phrozen.
The 2nd diagram here the AEM one is how I have always done solenoid EBC's like the E-01 etc...
Can't wait to get mine going!!! Thanks!
Old 07-03-2009, 03:49 PM   #82 (permalink)
TmP
TmP's Avatar
Member Number: 59394
How do you wire a MAC noid in???
That thing has got 2 wires sticking out.
This might sound dumb, but I'm a total noob with sparky stuff
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 07-03-2009, 10:17 PM   #83 (permalink)
harvboi05's Avatar
one goes to ground and one goes to the solenoid signal wire coming from the boost box.
Old 07-04-2009, 02:25 AM   #84 (permalink)
TmP
TmP's Avatar
Yeah, which one though?
Old 07-05-2009, 11:55 AM   #85 (permalink)
TmP
TmP's Avatar
Anyone?
Old 07-05-2009, 12:35 PM   #86 (permalink)
Trader Rating: (95)
Anyone?
It doesn't matter. They are both the same. Pick one and connect it to ground. Connect the other one to the Boost Box black wire of the RED / BLACK pair.
Old 07-05-2009, 02:41 PM   #87 (permalink)
TmP
TmP's Avatar
Oh...OK.
I'm a total sparky noob you see
Old 07-05-2009, 09:06 PM   #88 (permalink)
Member Number: 31376
Trader Rating: (12)
Default Ahhhhhhhhhhhhhhhhh
Quote: Originally Posted by never2muchboost View Post
here is the wiring diagram, more to follow
Jay,
I studied this diagram for about 20 minutes before installation. After running, sodering/connecting what I thought was the power/ground did I finally realize It was wrong. The pic says 16 gauge for both power and solenoid. 18 gauge black wire for ground. If memory serves correct, 16 gauge is a bigger wire than 18 gauge? So the ground wire is actually the 16 gauge and the solenoid is the 18 gauge. The fact that the two black and red wires were paired also helped me make this mistake. If the black wire has to be split in order to run to engine bay then why pair them? 2 hrs down drain so I am just frustrated. I realize the diagram is correct but its the gauge of the wires that are wrong. Unless it's just the wire package I got?
[x] MSD wires
[x] MBV
[X] Eibach pro kit
[ ] FM Wastegate (hit me up if your selling)
[X] N2MB boost box (you guys need this!)
I've modded/demodded this car twice in an attempt to sell her but just couldn't do it. 3X a charm???
allaboutboost is offline   Reply With Quote
Old 07-05-2009, 10:16 PM   #89 (permalink)
Trader Rating: (95)
No, you got it right. The 18 AWG BLACK wire actually looks bigger than the 16 AWG wire, because it has thicker insulation.
The wires are paired because when they are used for the WOT Box, they both go to the same splice point at the ignition coil power.
In this installation, the red of the pair provides power and the black of the pair powers the solenoid. The single black wire goes to ground.
there are pictures here:
N2MB Electronic boost controller installation guide
Old 07-06-2009, 01:10 AM   #90 (permalink)
Trader Rating: (12)
I just had to get a little more creative. Since I had already ran the larger blk wire to the engine bay, I just spliced the two wires backwards of the connector. That should do it. I forgot to get the six pack and is probably the root of my problems. side note, is there no fancy LED light to let you know its on? And how the hell do you unclip the TPS connector? Mine was covered in enough oil to satisfy the USA till 2011 and once I cleaned it up could not figure out how to unclip without breaking.. I pushed and pulled every little tab I could see. Thanks
Page generated in 0.21100 seconds with 14 queries
