Old 05-15-2009, 09:35 AM   #1 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
Default link to shift light instructions
N2MB Racing - WOT Box Shift LED and Button
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 06-03-2009, 04:02 PM   #2 (permalink)
Panco469's Avatar
Member Number: 60156
I need a How to: wiring for dummies.
Sorry can't understand what does every letter means. I think td and cts is for the LED and RD and DSR is for the button (optional). Right?
Panco469 is offline   Reply With Quote
Old 06-03-2009, 08:19 PM   #3 (permalink)
Sota's Avatar
Member Number: 31159
ignore the letters.
just wire the switch and LED to the correct pins and you'll be golden.
if you look carefully you'll notice that the male plug has a 1 near the #1 pin... especially on the solder version.
pin side.
it's $2 at radio shack btw. (PN# 276-1537)
they also have a removable pin crimp version for 20cents more.
here's a shot of the solder side... but from a 25 pin version (why they don't have a shot of the 9 pin version from this angle I don't know. but you get the idea.)
if you look carefully you can see the numbers above the pins in that image.
the 9 pin is numbered also.
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 09-04-2009, 07:02 PM   #4 (permalink)
tavenger5's Avatar
Member Number: 42245
Trader Rating: (29)
what's the max voltage that is output? I have a 12v light I would like to hook up - will it work or do I need a relay?
[font="Arial Narrow"]
2004 Black SRT-4 - all set for 500hp+
2005 Interlagos Blue BMW M3
tavenger5 is offline   Reply With Quote
Old 09-06-2009, 09:40 AM   #5 (permalink)
Member Number: 25854
Trader Rating: (95)
won't work. there isn't enough output current. only enough for an LED. there isn't enough power for a relay either.
you could use our nitrous cable, but that is probably more expensive then you want to spend for this.
Page generated in 0.13527 seconds with 13 queries
