Old 02-12-2007, 10:55 PM   #16 (permalink)
nightmare_rebuilt's Avatar
Member Number: 42066
Trader Rating: (47)
good find, what are other sympthoms of such failure?
i have an 03 and some times after a burnout, gears will srtoa lock up and rverse becomes a bitch, is my trany failing?
nightmare_rebuilt is offline   Reply With Quote
Old 02-12-2007, 11:04 PM   #17 (permalink)
Member Number: 6490
Just kinda curious, would a shifter with adjustable bump stops on it, that keep you from shoving the shifter too far into gear help remedy this problem. Something that keeps you from over engaging the shifter. I've seen it on B&M shifters for mustang and viper shifters.
T31HF04S turbo
Xtremeboost manifold
Xtremeboost custom 3" exhaust (cats are for pussies)
Xtremeboost Hard pipes
Greddy type S Bov
Tial wastegate
Xtremeboost huge front mount
Emanage/E01 set up
AEM wideband
Aeromotive fuel -6 feed and return setup
Aeromotive fuel regulator
Walbro fuel pump
Griffin aluminum radiator
180 thermostat
Xtremeboost battery relocator
MSD coil
MSD Wires
Xtremechrome polished valvecover
Polished intake manifold
SRT4DIRTBOY is offline   Reply With Quote
Old 02-13-2007, 07:18 AM   #18 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
yes it does help...its not a remedy though
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 02-13-2007, 03:09 PM   #19 (permalink)
Member Number: 6490
Is this something we can look forward to as a future product? I haven't seen one yet for the SRT.
Old 04-07-2007, 12:51 PM   #20 (permalink)
SRT of the Month
ERABBIT23's Avatar
Member Number: 39786
Trader Rating: (56)
same thing happened to my buddies car. Nice write up!
Worlds Fastest 5 Speed NSRT-4 ET and MPH
Only SRT-4 Trapping 150+ Without Nitrous
Built and Tuned by Realtune Powered by AGP Turbo and Cylinder Head by Darrel Cox Racing
Check Out ERABBIT23 on Youtube 4 Videos!
ERABBIT23 is online now   Reply With Quote
Old 04-09-2007, 08:36 AM   #21 (permalink)
weav343's Avatar
Member Number: 39433
i miss 4th at least once every time at the track, i'm gonna have to stop WOT shifting into 4th
[live]weav343[/live]
weav343 is offline   Reply With Quote
Old 04-09-2007, 08:43 AM   #22 (permalink)
Trader Rating: (59)
soon we will have our wot box in production but honestly you most likely broke the snap ring that holds the 3/4 synch in place.in that case nothing is really going to help.we do rebuild transmissions here though.
Old 04-09-2007, 12:58 PM   #23 (permalink)
weav343's Avatar
nah i don't think anything broke yet, still runs/shifts good, just every now and then it'll miss 3-4, only time i wot shift is at the track(for the most part),and as long as this piece coming out isn't rediculisly expensive i'll definitly get one just to be safe
Old 05-07-2007, 11:41 AM   #24 (permalink)
rosejm's Avatar
Member Number: 33812
Well you should have. Chuck includes his Rod Brakes on every Maddog STS that he sells. If you were looking for a stock shifter with this feature, you could order the Rod Brakes separately and modify your shifter OR I'm sure that Chuck could work something out and add them to a stock length shifter.
rosejm is offline   Reply With Quote
Old 05-19-2007, 07:11 PM   #25 (permalink)
Only1Balto's Avatar
Member Number: 43836
Trader Rating: (18)
Subscribed
Only1Balto is offline   Reply With Quote
Old 08-24-2007, 01:14 PM   #26 (permalink)
andrewsboots's Avatar
Member Number: 45507
Trader Rating: (39)
N2MB, Yesterday, before my shift selector broke I had zero problems with shifting. Right after I replaced my shift selector with an AGP piece, during the test drive, my third gear started grinding and it will only sometimes go into 3rd. Most of the time it just grinds and kicks it out.
Have you found an improvement on the OEM snap ring? an improved 3/4 synch.......is it even worth replacing with OEM parts?
andrewsboots is offline   Reply With Quote
Old 08-25-2007, 07:10 AM   #27 (permalink)
Trader Rating: (59)
well, we kinda found a resolution...we designed the wot box.check out the info on it here
New Product Announcement - The WOT Box! NEW PROGRESS INFO IN FIRST POST
that will eliminate the damage cause from "spirited" driving.as far as upgraded trans parts,unless you are making serious hp i wouldnt worry about it
Old 01-03-2008, 09:28 PM   #28 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
Hey. I have my shaft and gears out but Im wondering:
-Is there a way to tell or test to see if the snap ring is busted for the 3/4 synchro without removing the gears/snap ring?
-How the heck do you remove the snap ring
Either will work for me, the 2nd is prolly better so I know for sure what is up. Thanks
2.0L SOHC - 400whp 11/11/04 - still shooting for 450whp+
Check out my mods and pics here
Roach is offline   Reply With Quote
Old 01-04-2008, 03:11 PM   #29 (permalink)
Trader Rating: (59)
you have to remove the nut which requires a special tool,the fifth gear input has to be pressed off and then you can slide 4tgh gear off and you will have access to the 3/4 synch and snap ring
Old 01-04-2008, 03:53 PM   #30 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
guess i wont be doing that. any tips on reinstalling the bearing snap ring? guy at dodge said no tools needed, just to feed it on by hand?!?
Page generated in 0.19954 seconds with 13 queries
