Old 09-05-2009, 05:56 PM   #1 (permalink)
Member Number: 1189
Default Boost Box Settings Help!
I need some input. I just installed the box today and adjusted settings for each gear. The max boost in each gear is hitting the setting exactly. My problem is 3-5 psi oscillation in each gear. I've tryed a bunch of adjustments but it did not help.The oscillation is higher in 3rd and 4th. I'm running 1st-13,
2nd-17, 3rd-21, 4th-24. Its a Hahn 20G w/10lb. wastegate. I removed a Profec Spec II Controller which held steady boost. Has anybody else had this happen to them?
Squid57 is offline   Reply With Quote
Old 09-05-2009, 09:15 PM   #2 (permalink)
93stang434's Avatar
Member Number: 49690
What is your learning range set at?You might need to drop it down a little
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is online now   Reply With Quote
Old 09-06-2009, 09:33 AM   #3 (permalink)
Member Number: 25854
Trader Rating: (95)
support@n2mb.com
I think we've been talking and there is some wiring problem.
Page generated in 0.12245 seconds with 13 queries
