Boost Box issue - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 10-19-2012, 05:43 PM   #1 (permalink)
ares559's Avatar
Member Number: 81082
Default Boost Box issue
Ok so I bought this boost box last week and installed it. I have everything wired up and all vacuum lines hooked as per the n2mb instructions. My set up is an AGP .50 trim turbo and tial 38mm waste gate 10 psi spring, tuned on 28 psi. I have no boost leaks and all connections are soldered. My issue is, what ever values I place in the column a and b for boost by gear I get much more boost than that. I was told by Jon at n2mb to unplug the box and I should get my 10psi waste gate pressure. I did that and got a really quick 32 psi cutout open in third gear. I also have the over boost set to 29 which it didn't comply to. No matter how I configure the lines on the number 2 wga solenoid I get the same outcome. No matter how the solenoid is wired same out come. I am using a pretty brand new mopar wga solenoid only a couple of months old. I did put the waste gate directly to the turbo and got my waste gate pressue. Please help me with this issue I am pulling my hair out and about to send this back to them and say I no longer want it as it isn't working for me.
SRT: AGP .50 trim
Tuning on E85.
Tuned by Mindmelt101
ares559 is offline   Reply With Quote
Old 10-19-2012, 06:33 PM   #2 (permalink)
05_ACR_SRT4's Avatar
Member Number: 61818
Do Manuel settings(for high boost per instructions) I think you set gain to 0 and spring pressure to 0? I can't remember at this point.
Modded Stocker PTP S3K @ 24psi spike 22hold 27* of Timing
OLD DYNO 343.2whp 373.7wtq 91pump/meth with messed up wastegate & still not done tuning
NEW DYNO 348.6whp 400.4wtq 91pump/meth 27.3psi 19/22* timing
2005 Dodge Neon SRT-4 ACR: 12.293 @ 118.032 MPH
My Build Thread
05_ACR_SRT4 is offline   Reply With Quote
Old 10-19-2012, 06:49 PM   #3 (permalink)
ares559's Avatar
Yeah I was told to set the learn to 3 and the other two to 0 by n2mb. My issue comes into play when they told me to unplug the box to see if I get waste gate spring pressure. When I do that I get 32 psi and have to let off really quick. So that leads me to think there is a different problem right?
SRT: AGP .50 trim
Tuning on E85.
Old 10-20-2012, 08:35 AM   #4 (permalink)
ares559's Avatar
I can't be the only person that has had this issue
SRT: AGP .50 trim
Tuning on E85.
Old 10-20-2012, 09:21 AM   #5 (permalink)
emanuelcurly's Avatar
Member Number: 79089
overboost to 28
spring 0
learning 0
Gain 0
Try that, and set your boost points accordingly to run ur 28psi even though i think the boostbox only lets u run 27 without the 4bar sensors. U shouldnt have to put any gain on it because u are setting it manually. i Had this issue when i first got mine.
Gtx3076r Tuned by Turbo666
335whp on 93@ 24psi
405whp on e85@ 27psi
Best et 11.7@ 122.10!!!
emanuelcurly is online now   Reply With Quote
Old 10-20-2012, 06:00 PM   #6 (permalink)
ares559's Avatar
My main concern is the fact that I can't get waste gate spring pressure with the box electrically unplugged and just going through the solenoid. It will still hit 32-33 psi unplugged and n2mb told me I should be at my 10 psi waste gate pressure. They also said I should set the learning to 3 and everything else to 0. I ran everything at 0 before and it wouldn't control boost. The over boost didn't work either. Just a tad concerned that I may have a pre-existing problem.
SRT: AGP .50 trim
Tuning on E85.
Old 10-20-2012, 06:25 PM   #7 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Try this.
Run a line straight to wg from turbo see I'd you can get 10 psi if so your solenoid isn't workin right.
If not your wg is messed up. Use bottom line both for boost box and turbo to wg.
Old 10-20-2012, 06:33 PM   #8 (permalink)
ares559's Avatar
Yes I have done that already and got waste gate pressure no problem. But I've tried both solenoids I have and zilch. Oh well, guess now I have to find another flipping solenoid. I can blow through it with no issue through the top and middle ports. But when the vacuum lines are connected even I the box is out of the car it still over boosts. So weird. Driving me absolutely bonkers
SRT: AGP .50 trim
Tuning on E85.
Old 10-21-2012, 02:24 AM   #9 (permalink)
ares559's Avatar
Well I fixed the issue. I tested everything on the car and it just wasn't adding up. So I took off the waste gate line to the solenoid and blew through it and there ya go no air at the other end. There was a clog in the line and didn't allow any air to flow through. It's good now working great and I blew a manifold gasket now I have a fat exhaust leak at the head and manifold. At least that's where I think it is
SRT: AGP .50 trim
Tuning on E85.
Old 10-21-2012, 05:33 AM   #10 (permalink)
Well atleast u got it figured out bro. Trouble shooting our Cars can be a pain in the ass! Did u find a new solenoid yet? Now did ur manifold bolts come loose or u think its warped?
AG Free
335whp on 93@ 24psi
Old 10-21-2012, 12:18 PM   #11 (permalink)
ares559's Avatar
Looks like one of the bolts came loose that I saw last night. I have the AGP log manifold so I highly doubt that beefy thing is warped. The solenoids I have are fine. I could blow through each of the two wga solenoids I have with it disconnected from power. So I knew it was in the vacuum lines since that is the only thing I changed from the system that was working perfectly.
SRT: AGP .50 trim
Tuning on E85.
Old 10-21-2012, 01:18 PM   #12 (permalink)
ares559's Avatar
Waste gate gasket is leaking
SRT: AGP .50 trim
Tuning on E85.
Old 10-22-2012, 04:54 AM   #13 (permalink)
I'm on the same boat here. My bolts to from the dp to turbo rattled loose. Loctite is going to be! The 2nd time it's happened to me
AG Free
335whp on 93@ 24psi
Old 11-19-2012, 08:28 PM   #14 (permalink)
Member Number: 82349
My car is doing the same thing going to check this out tomorrow!
nsrt4 is offline   Reply With Quote
Old 11-20-2012, 10:20 PM   #15 (permalink)
Member Number: 25854
Hi,
That's a problem with your vacuum line connections. If you unplug the Boost Box from the harness, you should get only spring pressure. The vacuum lines may be swapped so that you get full boost all the time.
Shoot us an email at sales@n2mb.com for faster response.
Let me know if you have any questions.
Thanks,
Jon
