Old 03-11-2009, 07:15 PM   #1 (permalink)
Member Number: 58681
Default 2-step with nitrous?
I bought one of the N2MB 2-step and WOT box's because I've heard a lot of good things about them. I was getting kind of tired of inconsistent launches because I couldn't keep my foot still. With that said, I have ran a best of 11.56 @ 121mph running a ported stock turbo and a NX wet kit with a 75 shot.
I use a WOT switch on the throttle body and a MSD Digital window switch set from 3500k-6000k. After thinking about it and reading more on the box, is there any good way to wire it with my nitrous set-up? If i have to press the peddle to the floor it, it will arm my nitrous set-up. Suggestions? Thanks
11.56 @ 121mph w/ 1.700 60ft
Stock turbo + N2O
Jacobs is offline   Reply With Quote
Old 03-11-2009, 10:53 PM   #2 (permalink)
93stang434's Avatar
Member Number: 49690
Just set your window switch a little higher than your launch rpm by 100 rpm....if you launch at 4000 set the window switch at 4100.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 03-13-2009, 01:56 PM   #3 (permalink)
04yellowsrt's Avatar
Member Number: 32684
Trader Rating: (26)
good question Jacobs, I have been trying to figure out the same thing. I wouldn't set the window switch just a hair higher than the 2 step, because I have seen them go past where you have it set for just a split second, then come back down. Then if you set it too high, then depending on how high you go, you could risk coming below the window when you shift.
Anyone have an actual answer for this? besides just setting the window switch higher.
2004 Dodge Neon SRT-4 11.02@125
2004 Dodge Neon SRT-4 10.94@133
Quote: Originally Posted by addictedtosin View Post
04yellowsrt is probably THE BEST driver on the boards.
04yellowsrt is offline   Reply With Quote
Old 03-13-2009, 05:03 PM   #4 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
we are waiting for the parts to come in so we can make them but the answer is we have a kit that we will have available very shortly that will control your nitrous for you. the software for it functional and you can see the window switches and hysterisis in the windows interface. the only reason why it is not available yet is we are waiting on the parts so that we can use the serial cable to drive 500ma . this way you will be able to wire your nitrous solenoids directly to the wotbox. as soon as the parts come in we will make some and test them and then we will have them available for you
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Page generated in 0.14875 seconds with 13 queries
