» Tire Upgrade Garage
Old 03-26-2008, 12:54 PM   #31 (permalink)
Member Number: 25021
Quote: Originally Posted by DRASTIC. View Post
if i were really gay, you'd be on me like white on rice fool.
Don't you know it
Quote: Originally Posted by foxracing12002 View Post
what wga are you using?
Noob!!! NO WGA REQUIRED!! Just a external WG
-Matt- -Drastic- -314 HP 343TQ SAE-
05 SRT-4, 675cc injectors, 3 BAR, Forward Motion E1, FM FMIC, S2 WGA, PTP Intimidator Manifold and 3" O2 housing, Coolingmist Trunk mount W/I, SCT PRP , Auto Enginuity Datalogger, PTP fuel pump and re-wire, K&N FIPK, 3" Vibrant TBE, MSD coil, MSD wires, HKS SSQV, Prothane motor mount inserts, Autometer electronic boost gauge, AEM wideband, Catch can.
Old 03-26-2008, 12:55 PM   #32 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (30)
wow at the sig....
SARCASTIC.
FS: Complete turbo toys, O2 housings(stock/stage 3), stock IC, charge pipe, Stage 2 inj, Aeromotive FPR, plus other stock stuff...PM for offers
supermech21 is online now   Reply With Quote
Old 03-26-2008, 01:00 PM   #33 (permalink)
Member Number: 58932
Quote: Originally Posted by supermech21 View Post
wow at the sig....
whos? fox's?
some1 haxz0rd into my sn login.
im far from being tho, so dont worry.
Old 03-26-2008, 01:02 PM   #34 (permalink)
dirtyd99's Avatar
Member Number: 38128
^YOU CAN DO ITTTTT!!!!!!! ...lol
I WOT shift my lawn mower.
dirtyd99 is offline   Reply With Quote
Old 03-26-2008, 01:05 PM   #35 (permalink)
turbo2oh's Avatar
Member Number: 50941
Trader Rating: (18)
I wasn't getting meth either the other day, I just hard wired the pump to make sure it worked then replaced a terminal on boost switch then she was workin. Hopefully its just something cheap like the terminal. 21 for $1.99.
Powered by agp/bw s256 along with a race head from form and function performance and bc s3's. I am in the need for fuel..
turbo2oh is offline   Reply With Quote
Old 03-26-2008, 01:17 PM   #36 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (529)
gunna give it a full rundown tonite. full boost leak check.
ima drill out the bleed hole on the mbc slightly larger for better response
gunna loosen then tighten all clamps. check my manifold/wg
i will turn the boost up. fix my meth. and might adjust my cams.
i prefer to wait on my cams adjusted till my ems is installed.
thanks guys.
i know this turbo's gunna be the shit. at 15psi it fuckin moves. and i know its not the turbo thats the problem..
i gotta knitpick my whole car and see..
Crank the fuel pressure way up and see if you can pull some of it from down low. We just got done tuning a locals car in the start boost and mid range and he gained 150 RPM of spool time. I want to play with his car some more to see if I can get it to spool a little earlier. I know that we can get this turbo to spool by 3200 with a good tune and some cam adjustments.
Mike if you are running rich at your start boost you and I both know that will hurt the spool time (no expanding gases because your to rich at start boost). So get some more boost and either add fuel pressure (may make the problem worse) or borrow someones bigger injectors for a while. Trust me when you hit the sweet spot with this set up its a real eye opener.
Old 03-26-2008, 01:20 PM   #37 (permalink)
thanks guys.
I want to add one more thing. Just wait till you try 22 or 24 psi, your going to shit your thong right through the floor of your car . No but really I am serious, this turbo just starts to wake up around 19 to 20 psi and having felt one running at 22, its flat out amazing. It runs so good that I am thinking about pulling the big wheel stage 3 off my car and doing one for the wifes car. It has impressed me that much.
Old 03-26-2008, 01:34 PM   #38 (permalink)
i will raise it to 18psi tonite.
thats all i can go to for now.
EMS goes in next week.
itll be tuned to 23psi. pump/meth. 20* at spoolup rising to 24-25 at redline. 7300rev limiter. afters no higher than 11.5-11.8 at spoolup, and 11-11.5 at redline
then will do a race/meth tune at 26psi. 18* at spool, rising to 22 at redline.
i got 'er all figured out for the dyno tuning time...
if i can crack 500 at 26-27psi ill be happy. considering it takes about 28psi on a 50trim to do 480's i see no issue w/ 500 at 26...
Old 03-26-2008, 01:34 PM   #39 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (156)
what injectors are you going to run?
PTperformance PTP's Cali CREW Mole'
100% BONE STOCK.
Old 03-26-2008, 01:41 PM   #40 (permalink)
750s
theyre good to like 550 w/ a 1:1.
and i have TONS of meth. so i have enough fuel for like 580...
wont take it that high tho
Old 03-26-2008, 01:43 PM   #41 (permalink)
mole''s Avatar
750s
i have a set of S2 here if you wanna use them for a bit?
Old 03-26-2008, 01:47 PM   #42 (permalink)
thanks but im good.
ems might go on next weekend. if so, ill swap 750s in and turn the boost up to 20.
i already made a timing map to fit my likings. just gotta dial in my idle tune when it goes on the car
Old 03-26-2008, 01:47 PM   #43 (permalink)
D-ROK's Avatar
Member Number: 50159
you're so optimistic josh.
ill tkae you for a spin after. maybe i can suade you to get a mapclamp then.
I have a mapclamp sitting in my back seat. You want it?
Drastic. & Assoc.
D-ROK is offline   Reply With Quote
Old 03-26-2008, 01:48 PM   #44 (permalink)
tell josh to put it on.
bbq in 2 weeks bro. ur or myplace.
Old 03-26-2008, 01:49 PM   #45 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (52)
go back to sleep mole
PLASTIC.
lyncoo is online now   Reply With Quote
