Quote: Originally Posted by canadian_made_srt-4
Quote: Originally Posted by 90VNT
Quote: Originally Posted by blksrt404
Quote: Originally Posted by BLKDOUTSRT4
dam so all that im gonna ask a random question.......... when does the upgraded wheel see full spool ???
with my setup we saw spool 500 rpm faster than the stock S3...No lag at all in fact it was the opposite...Welcome to the club you wont be unhappy with the performance
Looks like it spools later. My stock S3 made more hp and tq till about 3600 rpm. After that you curve wins.
I'm not starting a fight here but it is spooling later 100% all you have to do is look at a S3 HOM graph.
S3 HOM dab3 made 240WHP and 380WTQ at 3200rpm 100% stock head/block
VS
50lb S3 HOM/DAB 3/ METH made 170WHP and 275WTQ at 3200rpm with race ported and polished head, cams and over sized valves?(not 100% on the valves).
S3 HOM dab3 made peak HP at 4800rpm
VS
50lb S3 HOM/DAB 3/ METH made peak HP at 5400rpm
looks like late spool to me again this was not to start a fight but to only show the facts right Jeff I can post the S3 graph if you wish just ask.
Not picking a fight Fred, Boy you won that race...I will let those who want to content or confirm your finds comment...
Meantime:
Here are the mods that support the numbers...
S3 with Toys
PTP S3 SST
Fasttrac PnP Head
Fasttrac 4 point racing cage
Cranes 16
Cams & Cam Gears
3 inch o2
Needswing with dump
AGP WG 18lb spring
AGP Race Intercooler
60mm TB
Devils Own progressive kit
Bottleneck & Hot fix to fuel pump
735 injectors running at 43psi
Return line
JMB ultimate pipes
Greddy BV
MSD ignition, coil and wires
6 puck hybrid clutch
Hurst Shifter
Thanks to all of you who have demonstrated their support. I really aprreciate it
Bottom line is "It is what it is"
