It looks like I may have an extra unit for sale. I have to get the parts first (now over 2 weeks for priority mail) and its killing me. I want to say that they will be for sale here in the next 2 weeks but if I can not get the ones that are in the mail now what happens when I try to get the next batch. I will keep you guys updated, thanks.
Still waiting... Car seems to be running well... S2 WGA FTMFW!!! It's a lot easier to tune with then the damn FM one. I can't wait to try this turbo out for you John... It should really make some nice numbers.
what are you boosting now?
i nver had no luck with the S2 WGA
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For all other questions send them to ptperformance@comcast.net For SoCal guys only! Now offering JD-M Specials!
I will let you know later after the computer has some time to adjust a little. But the difference is that I can control boost through the computer. The S2 WGA is a great WGA for drivability. People can't hold boost to redline with it because the computer actually dials boost way back in the upper RPM range. I can change that
Just got my Stage 2 WGA in as well. I cant wait to get my drivability back and still have the car running 22-24 PSI on spike holding 20+ to redline hehe...
I am holding 23 to redline ATM with the Stage 2 WGA (of course this is SCT tuned)... Dunno how much that's going to change after driving it a little and having the computer relearn everything.
One would think that as long as the PCM is programmed correctly for it and is happy(aka no knock or temp allows for it) then the PCM will give the car all the boost it is programed for. But once again that is as long as we have the tables setup correctly.
Bryan
Nope. The computer is designed to make a certain amount of power. If everything is "happy" it will still only make that amount of power... Or as in the "desired torque" table the amount of power listed.
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
Man and I am just now getting my v2 up and running. Now there is the stage 3. Hopefully I can match that 392hp on race gas that you posted a ways back. Then comes the nitrous. If I am not happy I will start bending tubing and drilling holes to get alot more nitrous in there. 10's basically stock turbo and nitrous or bust. I want to be the first to get into the 10s with the stock modified turbo.
On that 12.2 second run what was the psi set to, what did you use to tune, and what was the trap speed?
