350 sounds really good... with a intimidator mani will i still see full boost around 2800 still???the main reason i want this setup is the whole 'floor and go fast now' idea , its either this or a ball bearing and i don't see the point of getting a ball bearing unless i want to have 500hp and spinning tires everywhere
is the intimidator manny listed on the web site? if bought in conjuction with the sst v2 would it come fully assembled and ready to bolt on?
We will be adding it very soon.
The Intimidator and the SST will come together but you have to install them separate since the turbo and manifold will not fit down in the rear of the engine bay together. Gaskets and crush washers come with them so no need to get anything other then coolant when you install it.
thanks for a quick response by the way
yeah i sold alot of stuff off the forums but i had one bad deal off a 10 dollar item and the kid scummed out and gave it to me..... such is life though
Yes with fuel. Stage 0 will not support that much fuel with out setting an over boost code and putting the car into limp mode. If you can clamp the map sensor and then install 650 injectors then you will be good to go for 280 WHP or more.
