Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > PTPerformance
Old 08-25-2008, 08:40 PM   #31 (permalink)
Member Number: 64984
Quote: Originally Posted by dirtyd99 View Post
what psi was that 358hp run on?????
25-26psi in 4th gear falling to 18-19
Joe Dirt is offline   Reply With Quote
Old 08-25-2008, 09:23 PM   #32 (permalink)
Member Number: 37178
you only need s2's and a return for up to about 390whp the highest i have seen with s2's and a return was 421 with a gt3076. so s2 inj and a return should max out this turbo.
v5 ecut, 3" tbe stock tips, mbc, stg 1, solid mm's, k&n, safc2, agp evm, ptp 75 psi mod, ptp wga, 23/16, wideband, cm wi custom 5 nozzle(100%meth), 100 shot, tbolts, fuel rewire.dual aeroforces, 3"02
ported parts: exh mani., intake mani, turbo, tb
nitrous posts
timing,fpr, octane safc
http://www.srtforums.com/forums/f171/need-some-info-thanks-362819/
big turbo,hobbs switch
http://www.srtforums.com/forums/f171/n20-advice-evaluation-371119/
D_MONEY is offline   Reply With Quote
Old 08-26-2008, 09:13 AM   #33 (permalink)
Member Number: 9221
Trader Rating: (19)
how are you running a S2 map sensor on a stock pcm? NOT stage 0 its stock, fuck
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 08-26-2008, 10:01 AM   #34 (permalink)
dirtyd99's Avatar
Member Number: 38128
thats alot of boost (even though youre not ported)
60ft: 2.4 - 1/4: 13.2 on DR's
dirtyd99 is offline   Reply With Quote
Old 08-28-2008, 12:28 PM   #35 (permalink)
mole''s Avatar
Member Number: 17477
Trader Rating: (215)
possibly need some dw650s and a return line
those would work great for this setup..........
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4 DSP or Trinity
For SoCal guys only! Now offering JD-M Specials!
Old 09-01-2008, 09:02 PM   #36 (permalink)
SRTSLOW4ME's Avatar
Member Number: 49506
Trader Rating: (47)
nice dyno!!!
i have a whole fuel setup on my stock turbo and dynoed at 312hp and 345tq with an NX intercooler sprayer.... how much do you think this will improve my numbers??? im excited!!!!
SRTSLOW4ME is offline   Reply With Quote
Old 09-01-2008, 09:04 PM   #37 (permalink)
SRTSLOW4ME's Avatar
Trader Rating: (47)
and this just bolts up to your stock mani?
Old 09-04-2008, 11:25 AM   #38 (permalink)
mole''s Avatar
Quote: Originally Posted by SRTSLOW4ME View Post
nice dyno!!!
what psi are you running on your current setup?
Old 09-04-2008, 11:26 AM   #39 (permalink)
mole''s Avatar
Yes it does, but i would run a ported Mani with it.
Old 09-05-2008, 03:29 PM   #40 (permalink)
04BlueSkittle's Avatar
Member Number: 52567
Trader Rating: (35)
x2 are u throwing a code or what???
Quote: Originally Posted by Goldenshisno View Post
Wouldn't a little water be OK because when you heat up water it turns to steam the Hydrogen separates from the O2) and so all you would be adding is some extra air and hydrogen and last i checked that's pretty flammable.
Quote: Originally Posted by S10jimmi View Post
What? Steam is still H2O. It doesn't separate into H and O2, thats much more complex. It stays as H2O.
04BlueSkittle is offline   Reply With Quote
Old 09-05-2008, 03:42 PM   #41 (permalink)
Super Moderator
SRT of the Month
Member Number: 39843
Trader Rating: (183)
running a stage 2 sensor on a stock pcm is just like running a piggy back (well, more like a map clamp IMO) since it's going to pull fuel across the entire board seeing as how the PCM is seeing less boost than there really is
Old 09-05-2008, 04:06 PM   #42 (permalink)
Trader Rating: (35)
okay cause iwant to get some stage 2 injectors and pull fuel from my safc 2. it just seems easier then a return line and an upgraded fuel rail
Old 09-05-2008, 05:23 PM   #43 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (586)
Quote: Originally Posted by jdbeier38 View Post
What kind of injectors would one need to obtain around the same numbers if not a little better without meth?
650's would be minumum to get numbers like that and a good tune to go with it. I would also get a 255 pump HP and pump rewire. This should make you good to over 380 WHP.
DSP or Trinity
Old 09-05-2008, 11:32 PM   #44 (permalink)
SRTSLOW4ME's Avatar
Trader Rating: (47)
on my tune, my greddy ebc is set to 21psi on high.. holding all the way to redline.. maybe dropping to 20 if anything..
Old 09-05-2008, 11:33 PM   #45 (permalink)
SRTSLOW4ME's Avatar
Trader Rating: (47)
i was looking at the vband mani or the intimidator.....
