Old 06-20-2007, 12:21 AM   #1 (permalink)
Member Number: 7941
Default Question for PTP
Hey, I will be running my SST here soon but will not be running off PCM boost. I will be running from the turbo. So my question is, with my mods listed, what boost pressure should I be running to redline to get a steady 300HP?? I want to just run the set-up like a S/3 without toys for now. HP at the wheels not the crank. Black SRT said he ran PCM boost 20 spike falling to 16. But i want to run straight off the turbo. Thanks!!
AGP 50-trim, Stg 2 W/O, DW Stg 2's, SSA Front Mount, SSA turboback, JMB hard pipes and ultimate CAI, Raptor BOV, PTP 55 T/B, PTP clamp, PTP FPR mod, Walbro 255, Greddy Profec S, DCR Oil Kit, DCR Modifier, MSD 8.5's, NGK Iridiums, AEM Uego, Scan Gauge
jusyjus is offline   Reply With Quote
Old 06-20-2007, 12:41 AM   #2 (permalink)
master_1011's Avatar
Member Number: 3396
Trader Rating: (18)
I run PCM boost and hit 311 with the SST. If 300 is your goal, you should far surpass it. If your looking to keep it 'de-tuned' to 300.....then I guess the 20 down to 16 might work for you.
First SRT-4 sold on Guam
master_1011 is offline   Reply With Quote
Old 06-20-2007, 04:31 AM   #3 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (548)
First off get rid of that MSD coil. Then you can run 21 psi or more deppending on knock and AFR's. Your boost should not fall off at all if you have the correct WGA and MBC or EBC to control the boost. You should see 21 to 20 psi at redline.
Old 06-20-2007, 12:56 PM   #4 (permalink)
Member Number: 7941
^ i am hearing alot of people telling me to get rid of the MSD coil. what is so bad about it?? Is the screamin demon any good?? i have your coil heat sheild on it PTP!!
Old 06-20-2007, 02:03 PM   #5 (permalink)
The stocker seems to be the only one that has held up to any abuse. If its working for you then keep it but I have pulled over a handful of them off cars because of things that just didn't add up with HP levels and performance. They don't seem to down right fail, they just work 1/2 assed. Other then that, any other questions?
Old 06-20-2007, 08:08 PM   #6 (permalink)
Member Number: 3396
Trader Rating: (18)
So far my MSD has worked fine (knock on wood) but I still have my stocker as a back-up.
Old 06-21-2007, 02:15 PM   #7 (permalink)
May have got a good one I guess.
Page generated in 0.21270 seconds with 11 queries
